D-Link DWA-582 Wireless AC1200 DualBand PCIe Adapter
£35.04
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Utilises the latest 802.11ac dual-band technology, providing a blazing-fast, reliable connection to your network with wireless speeds of up to 867 Mbps
  • PCI Express provides a high-bandwidth connection to your computer whilst high power antennas boost signal strength to enhance wireless range and performance
  • Backwards compatible with all of your current wireless products, allowing you to integrate your existing setup with ease
  • Wired / Wireless: Wireless
  • Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
  • Form Factor: Plug-in card
  • Compatibility: PC
  • Type: Network adapter
Product codes
The DWA-582 Wireless AC1200 Dual-Band PCI Express Adapter connects your computer to a high-speed network and provides a blazing-fast Wireless AC connection with superior reception. Once connected, you can access your network's high-speed Internet connection while also getting secure access to shared photos, files, music, video, printers and storage.
Product Description D-Link Wireless AC1200 DWA-582 - network adapter
Device Type Network adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI Express x1
Bus Voltage 3.3 V
Dimensions (WxDxH) 2.5 cm x 12.1 cm x 7.9 cm
Weight 48.8 g
Data Link Protocol 802.11ac
Frequency Band 2.4 GHz, 5 GHz
Compliant Standards IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link DWA-582 Wireles...
£35.04
