D-Link DWM-222 Wireless Cellular Modem 4G LTE USB 2.0 150 Mbps
£74.59
15 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Provides high-speed connectivity in areas without Wi-Fi for blazing-fast Internet access when you’re on the road
  • Access the Internet using 4G LTE with download speed of up to 150 Mbps
  • Pocket-sized with no batteries or cables, making it easy to take with you when you’re traveling or simply on-the-go
Product codes
The DWM-222 4G LTE USB Adapter is a portable travel modem that allows you to connect to the Internet wherever you are. With fast downlink and uplink data rates, as well as low latency, it provides you with a high-performance and responsive connection when you're on the road.
D-Link DWM-222 - wireless cellular modem - 4G LTE
Wireless cellular modem - USB 2.0
External
Max Transfer Rate
150 Mbps
Cellular Protocol
GSM, GPRS, UMTS, EDGE, HSDPA, WCDMA, HSUPA, HSPA, LTE, DC-HSPA+
Apple MacOS X 10.5 or later, Microsoft Windows XP / Vista / 7 / 8 / 10
10.3 cm x 3.4 cm x 1.15 cm
33 g
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link DWM-222 Wireles...
£74.59
