We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The DXS-3400 Series switches feature a modular fan and power supply design for a high availability architecture. The hot-swappable design means that fans and power supplies can be replaced without affecting switch operation. Physical and virtual switch stacking allow the switches to be managed from a single IP address and provide redundancy for connected devices. The Switch Resource Management (SRM) feature allows the hardware table size to be changed, so that switch functions can be optimized based on the use of the switch. The DXS-3400 Series switches come with 3 modes; IP Mode, LAN Mode and L2 VPN Mode, which modify the size of the Layer 2 and 3 tables for optimum efficiency.
The DXS-3400 Series switches include feature rich software which satisfies the needs of Small Medium Business, Small Medium Enterprise, and campus users. It supports a wide range of Layer 2 and 3 functions such as VLANs, inter-VLAN routing, multicasting, Quality of Service (QoS), Virtual Router Redundancy Protocol (VRRP), Routing Information Protocol (RIP) v1/2, Next Generation RIP (RIPng), Policy-Based Routing (PBR), and security features. The DXS-3400 Series also includes an easy-to-use web interface and an industry standard CLI for improved management.
Product Description | D-Link DXS 3400-24SC - switch - 24 ports - Managed - rack-mountable | Device Type | Switch - 24 ports - L3 Lite - Managed - stackable | Enclosure Type | Rack-mountable 1U | Subtype | 10 Gigabit Ethernet | Ports | 20 x 10 Gigabit SFP+ + 4 x combo 10 Gigabit SFP+ | Performance | Switching capacity: 480 Gbps , Forwarding performance: 357.12 Mpps , Stacking bandwidth: 80 Gbps | Capacity | IGMP groups: 256 , MLD groups: 256 , ARP entries: 512 | MAC Address Table Size | 48K entries | Jumbo Frame Support | 12KB | Routing Protocol | RIP-1, RIP-2, VRRP, GRE, policy-based routing (PBR) | Remote Management Protocol | SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, CLI | Features | Flow control, VPN support, ARP support, load balancing, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Dying Gasp support, firmware upgradable, sFlow, PIM snooping, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, enhanced transmission selection, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, DHCP server, MLD snooping, Cable Diagnostics Function, bandwidth control, Unicast Reverse Path Forwarding (URPF), Uni-Directional Link Detection (UDLD), Deficit Weighted Round Robin (DWRR), LLDP support, DHCP relay, Data Center Bridging (DCB), DHCP client, Energy Efficient Ethernet, Dynamic VLAN Support (GVRP), Strict Priority (SP), 4MB packet buffer, Two Rate Three Color Marking (TRTCM), DiffServ Code Point (DSCP) support, Ethernet Ring Protection Switching (ERPS), hot swappable 3 fans, Single Rate Three Color Marking (SRTCM), system log, Head of Line Blocking Prevention, Deficit Round Robin (DRR), Priority-Based Flow Control (PFC), Link Aggregation | Compliant Standards | IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.1w, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1v, IEEE 802.1ag, IEEE 802.1AX, IEEE 802.1Qbb, IEEE 802.1Qaz, IEEE 802.1Qau | Power | AC 120/230 V (50/60 Hz) 2 A | Power Redundancy | Optional | Dimensions (WxDxH) | 44.1 cm x 38 cm x 4.4 cm | Weight | 7.45 kg |
