D-Link DXS-3400-24TC Managed L3 Gigabit Ethernet (10/100/1000...
D-Link DXS-3400-24TC Managed L3 Gigabit Ethernet (10/100/1000) Switch
£5,227.68
Delivery:
Key features
  • High availability and flexibility
  • Feature rich software
  • Lossless Ethernet
  • Energy efficient
Product codes
The DXS-3400 Series switches feature a modular fan and power supply design for a high availability architecture. The hot-swappable design means that fans and power supplies can be replaced without affecting switch operation. Physical and virtual switch stacking allow the switches to be managed from a single IP address and provide redundancy for connected devices. The Switch Resource Management (SRM) feature allows the hardware table size to be changed, so that switch functions can be optimized based on the use of the switch. The DXS-3400 Series switches come with 3 modes; IP Mode, LAN Mode and L2 VPN Mode, which modify the size of the Layer 2 and 3 tables for optimum efficiency.
The DXS-3400 Series switches include feature rich software which satisfies the needs of Small Medium Business, Small Medium Enterprise, and campus users. It supports a wide range of Layer 2 and 3 functions such as VLANs, inter-VLAN routing, multicasting, Quality of Service (QoS), Virtual Router Redundancy Protocol (VRRP), Routing Information Protocol (RIP) v1/2, Next Generation RIP (RIPng), Policy-Based Routing (PBR), and security features. The DXS-3400 Series also includes an easy-to-use web interface and an industry standard CLI for improved management.
D-Link DXS-3400-24TC - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L3 Lite - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
20 x 10GBase-T + 4 x combo 10 Gigabit SFP+
Performance
Switching capacity: 480 Gbps , Forwarding performance: 357.12 Mpps , Stacking bandwidth: 80 Gbps
IGMP groups: 256 , MLD groups: 256 , ARP entries: 512
MAC Address Table Size
48K entries
Jumbo Frame Support
12KB
Routing Protocol
RIP-1, RIP-2, VRRP, GRE, policy-based routing (PBR)
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
Flow control, VPN support, ARP support, load balancing, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Dying Gasp support, firmware upgradable, sFlow, PIM snooping, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, enhanced transmission selection, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, DHCP server, MLD snooping, Cable Diagnostics Function, bandwidth control, Unicast Reverse Path Forwarding (URPF), Uni-Directional Link Detection (UDLD), Deficit Weighted Round Robin (DWRR), LLDP support, DHCP relay, Data Center Bridging (DCB), DHCP client, Energy Efficient Ethernet, Dynamic VLAN Support (GVRP), Strict Priority (SP), 4MB packet buffer, Two Rate Three Color Marking (TRTCM), DiffServ Code Point (DSCP) support, Ethernet Ring Protection Switching (ERPS), hot swappable 3 fans, Single Rate Three Color Marking (SRTCM), system log, Head of Line Blocking Prevention, Deficit Round Robin (DRR), Priority-Based Flow Control (PFC), Link Aggregation
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.1w, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1v, IEEE 802.1ag, IEEE 802.1AX, IEEE 802.1Qbb, IEEE 802.1Qaz, IEEE 802.1Qau
AC 120/230 V (50/60 Hz) 2 A
Power Redundancy
Optional
44.1 cm x 38 cm x 4.4 cm
7.6 kg
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link DXS-3400-24TC M...
£5,227.68
