We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The EXO AC1900 Smart Mesh Wi-Fi Router brings hyper-fast AC1900 Wi-Fi, powerful McAfee protection, voice-based smart home Wi-Fi control and radical Wi-Fi mesh technology to your smart home. Because you know you deserve more than just a Wi-Fi signal.
Product Description | D-Link DIR-1960 - wireless router - 802.11a/b/g/n/ac - desktop | Device Type | Wireless router - 4-port switch (integrated) | Enclosure Type | Desktop | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz / 5 GHz | Data Transfer Rate | 1900 Mbps | Network / Transport Protocol | PPTP, L2TP, PPPoE, FTP, DHCP, IPv6 | Routing Protocol | Static IP routing, static IPv6 routing | Intelligent Assistant | Google Assistant, Alexa | Features | NAT support, VPN support, parental control, firmware upgradable, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Samba support, Guest Zone support, 4x4 MU-MIMO technology | Compliant Standards | IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Power | AC 100 - 240 V (50/60 Hz) | Dimensions (WxDxH) | 22.292 cm x 17.658 cm x 6.5 cm | Weight | 593 g | System Requirements | Apple MacOS X 10.6 or later, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | WPA, WPA2 |
Wi-Fi Rating | AC1900 |
Compliant Standards | IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IC, FCC |
Processor | 880 MHz |
RAM | 256 MB |
Flash Memory | 128 MB |
Status Indicators | Power, wireless, USB, Internet |
Internet of Things (IoT) | |
Expansion / Connectivity | |
Interfaces | WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A |
Aerial | |
Aerial | External |
Antenna Qty | 4 |
Power | |
Power Device | External power adapter |
Voltage Required | AC 100 - 240 V (50/60 Hz) |
Software / System Requirements | |
Software Included | McAfee LiveSafe |
OS Required | Apple MacOS X 10.6 or later, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 |
Dimensions & Weight | |
Width | 22.292 cm |
Depth | 17.658 cm |
Height | 6.5 cm |
Weight | 593 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
