We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Need super-fast Wi-Fi for your wire-free, all-streaming house? With a powerful processor, the AC2600 Smart Mesh Wi-Fi Router packs in enough of processing power to handle every networking task you throw at it. It's a powerful, intelligent home router with built-in McAfee protection for every device on your network. It supercharges your mesh network with D-Link's Wi-Fi Mesh technology so you can grow your mesh network by adding compatible D-Link routers and extenders. It even integrates voice assistant compatibility for Amazon Alexa and Google Assistant so you can control your network with voice commands. So stop settling for just a Wi-Fi signal - you deserve so much more.
Product Description | D-Link DIR-2660 - wireless router - 802.11a/b/g/n/ac - desktop | Device Type | Wireless router - 4-port switch (integrated) | Enclosure Type | Desktop | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz / 5 GHz | Data Transfer Rate | 2600 Mbps | Intelligent Assistant | Google Assistant, Alexa | Features | NAT support, parental control, firmware upgradable, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), 4x4 MU-MIMO technology | Compliant Standards | IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Power | AC 100 - 240 V (50/60 Hz) | Dimensions (WxDxH) | 22.292 cm x 17.658 cm x 6.5 cm | Weight | 610 g | System Requirements | Apple MacOS X 10.6 or later, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | WPA, WPA2 |
Wi-Fi Rating | AC2600 |
Compliant Standards | IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IC, FCC |
Processor | 880 MHz |
RAM | 256 MB |
Flash Memory | 128 MB |
Status Indicators | Power, wireless, USB, Internet |
Internet of Things (IoT) | |
Expansion / Connectivity | |
Interfaces | WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A |
Aerial | |
Aerial | External |
Antenna Qty | 4 |
Power | |
Power Device | External power adapter |
Voltage Required | AC 100 - 240 V (50/60 Hz) |
Software / System Requirements | |
Software Included | McAfee LiveSafe |
OS Required | Apple MacOS X 10.6 or later, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 |
Dimensions & Weight | |
Width | 22.292 cm |
Depth | 17.658 cm |
Height | 6.5 cm |
Weight | 610 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
