D-Link mydlink Home Monitor HD
£106.47
Delivery:
Standard: 1-3 working days
Key features
  • Monitor everything
  • Mydlink Home app-enabled
  • Wireless connectivity
  • Motion detection with night vision
  • HD clarity
  • Easy to setup
  • High definition
  • See in the dark
  • Motion and sound detection
Product codes
The mydlink Home Monitor HD allows you to monitor your home, whenever, from wherever. See everything in full color high definition 720p with sound. The built-in night vision allows you to see up to 5 meters even in complete darkness. It's easy to setup, connects to your home Wi-Fi and can even alert you when motion or sound is detected. What's more, it works with other mydlink Home smart devices to enable you to create a smart home without complicated setup, installation cost or monthly subscription charges.
mydlink Home Monitor HD - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in microphone
5.8 cm x 8.45 cm x 12.49 cm
160 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Optical Sensor Type
CMOS - 1/4"
Minimum Illumination
0 lux - IR - F2.4
Focal Length
2.38 mm
Focus Adjustment
(min distance 434 mm)
Lens Iris
F/2.4
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Voltage
DC 5 V
Motion sensor, date/time stamp, sharpness control, progressive scanning, saturation control, brightness control, contrast control, infrared cut filter, hue control, Wi-Fi Protected Setup (WPS), text stamp
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link mydlink Home Mo...
£106.47
