D-Link mydlink Home Panoramic HD Camera
£127.27
16 in stock
Delivery:
Standard: 1-3 working days
  • Type: Home security system
  • Stock Status: In Stock
Product codes
The mydlink Home Panoramic HD Camera allows you to monitor more of your home with a single camera. Forget pan, forget tilt, see everything instantly in full color high definition 720p with sound. The integrated microSD card slot1 allows you to record videos directly onto the camera when motion or sound is detected, without the need of a computer. It's easy to setup, connects to your home Wi-Fi and can even alert you when motion or sound is detected. What's more, it works with other mydlink Home smart devices to enable you to create a smart home without complicated setup, installation cost or monthly subscription charges.
Product Description mydlink Home Panoramic HD Camera - network surveillance camera
Device Type Network surveillance camera - fixed
Audio Yes: built-in microphone
Dimensions (WxDxH) 9.58 cm x 9.58 cm x 13.75 cm
Weight 165 g
Connectivity Technology Wireless
Camera Colour - Day&Night
Max Resolution 1280 x 720
Frame Rate (max) 30 frames per second
Motion Detection Yes
Optical Sensor Type CMOS - 1/2.7"
Minimum Illumination 0.5 lux - colour , 0.1 lux - B&W , 0 lux - IR
Focal Length Control Fixed focal
Focal Length 1.72 mm
Focus Adjustment (min distance 50 cm)
Lens Iris F/2.0
Interfaces IEEE 802.11g, IEEE 802.11n, IEEE 802.11a, IEEE 802.11ac
Voltage DC 5 V
Features Date/time stamp, Motion Detection Technology, sound activated recording, password protection
Environmental Parameters (operating) 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link mydlink Home Pa...
£127.27
