D-Link mydlink Home Smoke Detector
£56.61
Delivery:
Key features
  • Mydlink Home Smoke Detector
  • Peace of mind
  • Battery powered
  • Your mydlink Home
  • Set up, control, monitor and protect your home
Product codes
Protect your home and loved ones with the mydlink Home Smoke Detector. A built-in audio alarm alerts you whenever smoke is detected and sends a push notification to your smartphone or tablet when you're away from home. It's easy to set up and manage with the mydlink Home app, and connects to your router via the mydlink Home - Connected Home Hub. It works with other mydlink Home devices, such as the Smart Plug which can turn on a light when smoke is detected at night, or Siren to give you a loud audio warning either in a different part of your home or even at a location away from your home. mydlink Home enables you to create a smart home without complicated set up, installation costs or monthly subscription charges.
mydlink Home Smoke Detector - smoke sensor
Smoke sensor
Functions
Siren
Wireless - Z-Wave
Supported Host Device OS
iOS, Android
12 cm x 5.3 cm x 12 cm
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link mydlink Home Sm...
£56.61
