D-Link PoE injector - 30 Watt
£43.50
22 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Offers a compact, powerful and cost-effective solution for PoE/PoE+ devices, giving you maximum deployment flexibility
  • Installed wireless access points and network video cameras on walls or ceilings where power outlets are not available
  • Plug-and-play installation makes setup simple, with no software or additional steps required, allowing you to get up and running right away
  • Stock Status: In Stock
Product codes
The IEEE 802.3at (PoE+)/802.3af (PoE) compliant DPE-301GI Gigabit PoE+ Injector is designed to supply data and up to 30 watts of power to PoE-enabled devices such as network cameras and wireless access points.
Product Description D-Link DPE-301GI - PoE injector - 30 Watt
Device Type PoE injector - external
Weight 70 g
Output Voltage 54 V
Power Capacity 30 Watt
Output connectors 1 x RJ-45
Included Accessories Power adapter
Dimensions (WxDxH) 10.98 cm x 6.22 cm x 2.45 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link PoE injector -...
£43.50
