The DWL-P200 Power Over Ethernet (PoE) adapter is designed to supply operational power to surveillance cameras and wireless LAN devices such as access points, bridges and routers. It enables power current to travel on the Ethernet network cable, thus eliminating the need to directly connect a power supply to the wireless LAN device. The DWL-P200 supports both 5VDC and 12VDC power requirements. Power requirement can be selected through a DIP switch.
Facilitates Installation:
The Power Over Ethernet allows you to install the wireless LAN device and surveillance camera at places such as on a building rooftop, on or near a ceiling, or other difficult places where power is not easily accessible. The idea is increase the usefulness of your camera and wireless LAN to provide connectivity to users regardless of their proximity to a power outlet or a network cable.
Data and DC Power Transmission on the Same Network Cable:
On a standard UTP Category 5 cable, only two pairs (pins 1, 2, 3 and 6) are used for Ethernet data transfer. Power Over Ethernet is designed to take advantage of the unused pins of the remaining pair of cable wires. Consequently, a single Category 5 cable will now carry both Ethernet data and DC power. The idea is to supply the remote end with power and the requirements of Ethernet connectivity via a single Cat 5 cable.
Base Unit and Terminal Unit:
The DWL-P200 includes a base unit and a terminal unit. At one end, the base unit inserts DC voltage into the unused wires (pins 4, 5, 7 and 8) of the network cable. At the other end, the terminal unit splits the data and DC power apart. Data signals continue to travel on remaining network cables, while DC power is fed into the power adapter, which connects to an AC power outlet.
Product Description | D-Link DWL-P200 - PoE injector + PoE splitter | Device Type | PoE injector + PoE splitter | Input Voltage | AC 100-240 V | Output Voltage | +5, +12 V | Output connectors | 1 x power DC jack | Dimensions (WxDxH) | 5.2 cm x 8.1 cm x 2.8 cm |
General | |
Power Device | |
Frequency Required | 50/60 Hz |
Power Output Connectors Details | 1 x power DC jack |
Expansion / Connectivity | |
Interfaces | 1 x LAN - RJ-45 |
Miscellaneous | |
Compliant Standards | FCC Class B certified, C-Tick |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Operating | 10 - 80% |
Humidity Range Storage | 5 - 90% |
Dimensions & Weight | |
Width | 5.2 cm |
Depth | 8.1 cm |
Height | 2.8 cm |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
