D-Link Securicam Wireless N HD Day & Night PTZ Camera H....
D-Link Securicam Wireless N HD Day & Night PTZ Camera  H.264  MJPEG
Key features
  • Crisp video clarity with high definition 720p resolution
  • More viewing with pan, tilt, digital zoom
  • Record up to 5x more video compared to MJPEG with H.264 compression
  • Automatic day/night vision with IR LEDs
  • Enhanced motion detection with built-in PIR sensor
  • Flexible placement with Wireless N connectivity
  • Local recording with a microSD card
  • Two-way audio with built-in mic and audio out port
  • Easy setup Wireless 802.11n compliant and Wi-Fi Protected (WPS) button
Product codes
mydlink™ Cloud Services: the easiest way to monitor your home
Connecting a camera to your network and accessing it has traditionally required complex configuration. mydlink™ Cloud Services make it easy to access your camera from wherever you are, whenever it's convenient for you. A step-by-step guide has your camera up and running in a matter of minutes. Then via a simple website you can set up a mydlink™ account allowing you to view and manage your camera from any Internet connected computer. If you have more than one camera, you can add it to your existing mydlink™ account and watch all your cameras from a single location.
Accessing your cameras on the go is easy too. Just download the mydlink™ app for your iPhone®, iPad® or Android™ and you can quickly and easily view your camera feed from anywhere with a wireless or 3G connection.
Thanks to this app, you can monitor on-the-go even if you don't have access to a computer.
Cover and protect wider areas
This sophisticated home camera provides you with the ideal 24-hour monitoring solution, allowing you to see up to 340 degrees of any room it is placed in thanks to its Pan/Tilt feature. Control its Pan/Tilt feature via the mydlink™ portal, the included remote control, or the mydlink™ app. This camera can also be set to automatically move to specific preset positions, allowing the camera monitor a wider area.
Night vision
The Pan/Tilt/Zoom Cloud Camera comes with built-in infrared LEDs that allow for monitoring even in complete darkness. The 5-metre illumination distance makes it suitable for monitoring whatever is important to you: whether it is your baby in the nursery or your office by night.
A complete monitoring system
This cloud-enabled camera includes a microSD card slot to record audio and video directly onto the camera, without the need of a computer being switched on. You can setup the camera to record only when motion is detected, or continuously, via the camera's intuitive web interface. Once the microSD* card is at capacity, older footage will be recorded over. You can watch and examine recorded video directly from the mydlink™ portal later on from anywhere, at any time.
The built-in PIR sensor can detect motion and trigger email alerts. An additional sensor attached to a door or window can be connected to its standard I/O port. All these features can be easily configured via the User Interface, which makes this camera a truly comprehensive home monitoring system.
*microSD card not included.
Header / Manufacturer
D-Link
Header / Product Line
D-Link DCS
Video Input / Camera Type
Network CCTV camera
Header / Model
5222L
Video Input / Max Digital Video Resolution
1280 x 720
Video Input / Camera Mechanical Design
Pan / tilt
CCTV / Panning Range (degree)
340
CCTV / Tilting Range (degree)
120
CCTV Camera Sensitivity / Minimum Illumination (lux)
0
Environmental Parameters / Min Operating Temperature
Header / Compatibility
Android, Apple iOS, Mac, PC
Header / Packaged Quantity
1
CCTV / Compatible Sensor Size
1/4"
Optical Sensor / Sensor Size
1/4"
Dimensions & Weight / Depth
10.32 cm
Dimensions & Weight / Width
12 cm
Dimensions & Weight / Height
13 cm
Video Input / Frame Rate
30 frames per second
Dimensions & Weight / Weight
340 g
Environmental Parameters / Max Operating Temperature
Optical Sensor / Sensor Size (metric)
6.4 mm ( 1/4" )
CCTV / Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, ICMP, IGMP, NTP, PPPoE, RTCP, RTP, RTSP, SMTP, TCP/IP, UDP/IP
Networking / Network Interface
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Networking / Network Interfaces
Fast Ethernet
Lens System / Focal Length Control
Fixed focal
Video Input / Digital Video Format
H.264, MJPEG
General / Compression Format
H264, MJPEG
Networking / Remote Management Protocol
HTTP, HTTPS
Video Input / Image Recording Format
JPEG
Flash Memory / Supported Memory Cards
microSD Card
System Requirements / OS Required
Microsoft Windows Vista / 7 / 8, Microsoft Windows XP SP3
Miscellaneous / Product Colour
White
Video Input / Audio Support
Video Input / Day & Night Functionality
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link Securicam Wirel...
