D-Link USB 2.0 4-Port Hub
Key features
  • Connect up to four more USB peripheral devices to your notebook, laptop, or desktop computer
  • This USB Adapter features a black Fast-Charge port, perfect for charging power-hungry mobile devices like the iPad
  • Connect this device to a power outlet and an available USB port on your notebook, laptop or computer and installation is complete
  • It’s compact size allows you to conveniently carry it with you wherever you go
Product codes
The D-Link® 4-Port USB 2.0 Hub (DUB-H4) provides four additional USB 2.0 ports to your PC or Mac, allowing you to connect USB devices such as digital cameras, external hard drives, flash drives, and printers. Providing data rates of up to 480Mbps*, this 4-port hub is the ideal solution for transferring data between your computer and external USB storage devices.
Simple plug-and-play
Designed to provide quick and easy access, the DUB-H4 is equipped with four type "A" downstream ports for connecting USB peripherals or other USB hubs. The DUB-H4 does not require any software or complicated installation process. It is a Plug-and-Play device that provides seamless connectivity to both PCs and Macs.
You can simply connect the DUB-H4 to your computer and start connecting your USB devices.
Backward compatible with USB 1.1
The DUB-H4 is backward compatible with USB 1.1** devices, ensuring connectivity between your computer and legacy USB devices. Diagnostic LEDs located on the front of the device provide power state and port status.
The D-Link 4-Port USB 2.0 Hub (DUB-H4) is an excellent choice for adding more USB ports to your computer for connecting your existing peripherals as well as adding the latest USB cameras and external storage devices.
For comparison purposes only. Maximum transfer rate based on USB 2.0 specifications. Actual data throughput will vary.
Using a USB 1.1 port will affect device performance.
Header / Manufacturer
D-Link
USB Hub
Networking / Connectivity Technology
Wired
Ports
4
Header / Packaged Quantity
1
Speed
480 Mbps
Hi-Speed USB
Networking / Form Factor (FE)
Desktop
External
Header / Model
H4
Networking / Type
Hub
Header / Compatibility
PC
Networking / Subcategory (FE)
Peripheral sharing and hubs
Networking / Subtype
USB
Miscellaneous / Compliant Standards
VCCI
Dimensions & Weight / Height
29mm
Dimensions & Weight / Width
63mm
Dimensions & Weight / Depth
104mm
Environmental Parameters / Min Operating Temperature
Environmental Parameters / Max Operating Temperature
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
