D-Link Vigilance Full HD 360 PoE Dome Camera
£166.89
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
DCS-4622 is a Full HD 360° network camera as an entry type for video surveillance and security. This camera adopts 3MP progressive scan CMOS sensor. The camera is designed for both indoor and day/night applications, thus, the camera built-in removable IR-cut filter and IR LED, which can support long distance. The DCS-4622 has a built-in 802.3af compliant PoE module, that simplifies installation by providing power and networking connectivity with a single cable, reducing the need to drill holes or lay additional cabling.
Product Description D-Link DCS 4622 - network surveillance camera
Device Type Network surveillance camera - fixed dome
Audio Yes: built-in speaker, built-in microphone
Dimensions (WxDxH) 9.7 cm x 9.7 cm x 4.83 cm
Weight 210 g
Connectivity Technology Wired
Camera Colour - Day&Night
Max Resolution 1920 x 1536
Frame Rate (max) 25 frames per second
Motion Detection Yes
Optical Sensor Type CMOS - 1/3" - 3 MP
Minimum Illumination 0.5 lux - colour , 0.25 lux - B&W , 0 lux - IR
Focal Length 1.1 mm
Focus Adjustment (min distance 30 cm)
Lens Iris F/2.0
Tilting Range (degree) 15
Interfaces Ethernet 10Base-T/100Base-TX
Voltage DC 12 V / PoE
Features Sharpness control, saturation control, brightness control, contrast control, Wide Dynamic Range (WDR), built-in IR illuminator, exposure control, ICR filter, sound detection
Environmental Parameters (operating) 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link Vigilance Full...
£166.89
