D-Link Vigilance Full HD Outdoor PoE Mini D Camera
£192.39
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Allows the camera to see objects in contrasting light conditions
  • Ideal for entrances or windowed foyers where it is necessary to monitor both indoor and outdoor areas, or shadowed areas as well as brightly lit areas
  • 3 axis mechanism gives horizontal, vertical and rotation adjustments
  • This provide greater flexibility to achieve the view you want, whether the camera is mounted on the ceiling or wall
  • Stock Status: In Stock
Product codes
The Vigilance Full HD Outdoor PoE Mini Dome Camera is a professional, full featured full HD Camera with IP-66 (weather-proof) housing, specifically designed to withstand adverse weather conditions. Incorporating IR LED illuminator, WDR and 3DNR support, you get up to 30 meters night vision and clear detailed images in contrasting and low light environments.
Product Description D-Link Vigilance DCS-4802E Full HD Outdoor PoE Mini Dome Camera - network surveillance camera
Device Type Network surveillance camera - pan / tilt - outdoor - vandal-proof
Dimensions (WxDxH) 11.3 cm x 11.3 cm x 7.77 cm
Weight 635 g
Connectivity Technology Wired
Camera Colour - Day&Night
Max Resolution 1920 x 1080
Frame Rate (max) 30 frames per second
Video Modes 1080p
Optical Sensor Type CMOS - 1/3" - 2 MP
Minimum Illumination 1 lux - colour - F2.0 , 0.5 lux - B&W - F2.0 , 0 lux - IR
Focal Length 2.8 mm
Lens Iris F/1.8
Panning Range (degree) 350
Tilting Range (degree) 60
Interfaces Ethernet 10Base-T/100Base-TX
Voltage DC 12 V
Features Motion sensor, Power over Ethernet, e-mail alerts, Wide Dynamic Range (WDR), 3D Noise Reduction Technology, Open Network Video Interface Forum (ONVIF), NAS-Ready
Environmental Parameters (operating) -30 °C - 50 °C; 20 - 80% (non-condensing) relative humidity
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link Vigilance Full...
£192.39
