D-Link Vigilance HD Wireless Camera
Key features
  • Detect motion by measures infrared light radiating from moving objects that emit heat
  • Greatly reduces false alarms compared to image-based motion detection
  • Helps to reduce unnecessary storage wastage caused by false triggers
  • Integrated microSD card slot allows you to record videos or take snapshots without the need for additional backend software or storage
  • Record continuously or when motion is detected
  • • Supports up to 32GB microSD card
Product codes
The Vigilance Wireless HD Camera is a professional, full featured HD camera that is easy to install and highly affordable. Capable of viewing up to 10 metres at night thanks to its infrared LED illuminator, this camera can monitor an area even in complete darkness.
A built-in microphone and speaker allows for 2-way communication, which is ideal for use in entryways or for caretaker applications. A passive infrared (PIR) sensor detects motion near the camera, allowing it to automatically record video and send a notification when motion is detected.
Vigilance range
The Vigilance Range offers professional, full featured high definition video surveillance that is easy to install and highly affordable. The range consists of cameras designed specifically to meet different surveillance and environmental requirements. From standalone surveillance solutions that allow you to record video without additional software or equipment, to weather/vandal-proof cameras for harsh environments.
Security Installer Focused
Specifically designed for any security installer looking to offer digital video surveillance, this versatile range of cameras is designed for easy selection and simple installation. You'll be able to guide your customers to the right choice for their needs and they will be delighted with the quality, reliability and straightforward ease-of-use that Vigilance delivers.
D-Link DCS-4201 - network surveillance camera
Network surveillance camera - fixed
Audio
Built-in speaker, two-way audio capability, built-in microphone
5.8 cm x 3.07 cm x 9.5 cm
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Frame Rate (max)
30 frames per second
Motion Detection
Optical Sensor Type
CMOS - 1/4"
Minimum Illumination
1 lux - colour - F2.4 , 0.5 lux - B&W - F2.4 , 0 lux - IR
Focal Length Control
Fixed focal
Focal Length
1.8 mm
Lens Iris
F/2.4
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
IR filter, e-mail alerts, ONVIF support, 3D Noise Reduction Technology, Motion Detection Technology, Event Notification
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link Vigilance HD Wi...
