D-Link Wi-Fi Smart Plug
£30.28
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Control your appliance from anywhere
  • Compact design
  • Type: Smart plug
  • Compatible With: Alexa, Google Assistant
  • Stock Status: In Stock
Product codes
The mydlink Wi-Fi smart plug is a versatile and easy-to-use device that allows you to control an electrical appliance from your smartphone or tablet, wherever you are. You can set automatic schedules to turn on or off appliances such as lamps and heaters at specific times and days of the week.
Product Description mydlink - smart plug
Product Type Smart plug
Functions Turn electronics on/off
Connectivity Wireless - 802.11n
Supported Host Device OS iOS, Android
Dimensions (WxDxH) 7.4 cm x 3.8 cm x 9.5 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£30.28
