D-Link Wireless 4G router - WWAN - 4 port switch - 802.11b/g/...
D-Link Wireless 4G router - WWAN - 4 port switch - 802.11b/g/n/ac
£114.24
42 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Simply insert your 4G-enable SIM card to share high-speed mobile Internet with multiple devices via Wi-Fi or Ethernet cables
  • Enjoy combined Wi-Fi speeds of up to 733 Mbps with dual-band technology, so you can share files faster
  • Load sharing and fail-safe Internet with concurrent fixed line and mobile Internet support
  • Type: Wireless router
  • Standards: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a + 4 more
  • Speed: 733Mbps
  • Stock Status: In Stock
Product codes
D-Link's DWR-953 Wireless AC750 4G LTE Router allows you to access and share your super-fast 4G LTE mobile broadband with multiple devices. Once connected, you can transfer data, stream media, and send SMS messages. Simply insert your SIM card and share your 4G LTE Internet connection through a secure wireless network or by using any of the four Fast Ethernet LAN ports. Simultaneous 4G LTE/3G mobile Internet and fixed broadband Internet support allows you to combine Internet connections to give you faster Internet speeds. You can also set up fail-safe Internet should either connections fail.
Product Description D-Link DWR-953 - wireless router - WWAN - 802.11a/b/g/n/ac - desktop
Device Type Wireless router - wireless cellular modem - 4-port switch (integrated)
Enclosure Type Desktop
Cellular Protocol GSM, GPRS, UMTS, EDGE, HSPA, HSPA+, DC-HSPA+, FDD LTE, TDD LTE
WAN Ports Qty 1
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band 2.4 GHz / 5 GHz
Features NAT support, Stateful Packet Inspection (SPI), Wi-Fi Protected Setup (WPS), reset button
Compliant Standards IEEE 802.3u, IEEE 802.3i, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Dimensions (WxDxH) 17 cm x 18 cm x 8 cm
Weight 400 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link Wireless 4G rou...
£114.24
