D-Link Wireless AC1200 Simultaneous Dual-Band PoE Outdoor AP
£184.72
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Harness the power of Wireless AC, enjoying combined wireless speeds of up to 1200 Mbps , perfect for high-demand business applications
  • IP68 weatherproof housing and weathershield makes the DAP-3662 ideal for the most demanding of surveillance applications
  • Configure to use as an Access Point, a Wireless Distribution System (WDS) with Access Point, a WDS/ Bridge, or a Wireless Client
  • Type: Radio access point
  • Connectivity: Wireless
  • Speed: 1200Mbps
  • Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
  • Compatibility: PC
Product codes
The D-Link DAP-3662 Wireless AC1200 Simultaneous Dual-Band Outdoor PoE Access Point is a versatile, high power outdoor access point designed with harsh weather resistant features making it an ideal solution for creating outdoor wireless hotspot networks.
This DAP Access Point is Perfect for deployment in locations such as manufacturing plants, industrial automation, convention halls, stadium facilities, airports, school campuses, golf courses, marinas or virtually any venue requiring a robust wireless solution.
Super-fast Wireless AC Performance
The D-Link DAP-3662 delivers reliable, high-speed wireless performance using the latest 802.11ac standards with maximum wireless signal rates of up to 900 Mbps over the 5 GHz band and 300 Mbps over the 2.4 GHz band. This, coupled with support for the Wi-Fi Multimedia (WMM) Quality of Service (QoS) feature, makes it an ideal access point for audio, video and voice applications. When enabled, QoS allows the DAP-3662 to automatically prioritise network traffic according to the level of interactive streaming, such as high definition video steaming or VoIP. The QoS feature can be adjusted through the DAP-3662’s web GUI using a drop-down menu option to select customised priority rules. Additionally, the D-Link DAP-3662 supports load balancing to ensure maximum performance by limiting the maximum number of users per access point.
Built for the outdoors
Specially built for outdoor use, the D-Link DAP-3662 has an IP68 weatherproof housing that protects it from dirt and rain. Wireless AC connectivity and high powered antennas means you can put it anywhere within range of your wireless network, giving you the freedom to install it right where you need wireless coverage.
Security
To help maintain a secure wireless network, the D-Link DAP-3662 supports both Personal and Enterprise versions of WPA and WPA2 (802.11i), with support for RADIUS server backend and a built-in internal RADIUS server allowing users to create their accounts within the device itself. This DAP-3662 Access Point also includes MAC address filtering, wireless LAN segmentation, SSID broadcast disable, rogue AP detection, and wireless broadcast scheduling to further protect your wireless network. The DAP-3662 includes support for up to eight VLANs per band for implementing multiple SSIDs to further help segment users on the network. It also includes a wireless client isolation mechanism, which limits direct client-to-client communication. Additionally, the D-Link DAP-3662 supports Network Access Protection (NAP), a feature of Windows Server 2008, allowing network administrators to define multiple levels of network access based on individual client’s needs.
Multiple Operation Modes
To maximise total return on investment, the D-Link DAP-3662 can be configured to optimise network performance based on any one of its multiple operation modes: Access Point, Wireless Distribution System (WDS) with Access Point, WDS/Bridge (No AP Broadcasting), and Wireless Client. With WDS support, network administrators can set up multiple DAP 3662s throughout a facility and configure them to bridge with one another while also providing network access to individual clients. The DAP-3662 also features advanced features such as load balancing and redundancy, for fail-safe wireless connectivity.
Versatile Access Point Functionality
The D-Link DAP-3662 allows network administrators to deploy a highly manageable and extremely robust simultaneous dual-band wireless network. The DAP-3662 can provide optimal wireless coverage over either the 2.4 GHz (802.11b, 802.11g, and 802.11n) or the 5 GHz (802.11a, 802.11n, and 802.11ac) band. The DAP-3662 has integrated 802.3af Power over Ethernet (PoE) support, allowing this device to be installed in areas where power outlets are not readily available.
Network Management
Network administrators have multiple options for managing the DAP-3662, including web (HTTP), Secure Socket Layer (SSL, which provides for a secure connection to the Internet), Secure Shell (SSH, which provides for a secure channel between local and remote computers), and Telnet. For advanced network management, administrators can use the D-Link Central WiFiManager to configure and manage multiple access points from a single location.
The D-Link AP-3662 has a wireless scheduler feature, which turns off wireless functionality when it isn’t needed, saving power. With simultaneous dualband functionality, PoE support, extensive manageability, versatile operation modes, and solid security enhancements, the DAP-3662 provides small to medium business and enterprise environments with a business-class solution for deploying a wireless network.
Free Central Wi-Fi Manager
Manage up to 1000 APs from a single location, complete with a multitenant structure that provides multi-layer management authority. Allows you to be in control of your wireless network from anywhere in the world through the Internet by using a web browser on your PC, smartphone or tablet. Enterprise-level features such as bandwidth optimisation, captive portal and RF optimisation help satisfy the needs of the modern business environment.
Web-based management
Software controller that can be installed on a Microsoft Windows computer and accessed through any device with a web browser such as a smartphone, tablet or computer
Multi-site management
Multiple distributed sites can be managed from a central location. The multi-tenant architecture provides multi-layer management authority
NAT pass-through
Controllers can manage wireless access points in remote locations even if they are behind a NAT device (router or firewall)
Captive portal and access control
Supports local DB, external RADIUS, LDAP, POP3 and Wi-Fi passcode authentication
Supports user access control
Auto radio frequency (RF) management
Supports automatic channel and output power optimisation
Bandwidth optimisation
High-performance connectivity withIEEE 802.11ac wireless
Up to 1200 Mbps combined wireless speeds
Two (2) 10/100/1000 Gigabit Ethernet RJ45 ports
WPA/WPA2 - Enterprise/Personal WPA2 - PSK/AES over WDS
IP68 water and dust-proof housing for the most demanding of surveillance applications
Weather resistant for temperatures between -30C and 60C
Gore-Tex Technology repels liquid water while allowing for heat and humidity dissipation
Simultaneous dual-band connectivity for increased network capacity
Traffic control/QoS
Internal RADIUS server
Web redirection
ARP spoofing prevention
WLAN partition
Supports 802.3af Power over Ethernet
Wall and pole mounting hardware included
Product Description D-Link DAP-3662 - radio access point
Device Type Radio access point
Form Factor External - outdoor
Data Link Protocol IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band 2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported PoE
Dimensions (WxDxH) 27.7 cm x 24 cm x 5 cm
Weight 981 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link Wireless AC1200...
£184.72
