D-Link Wireless AC1200 Simultaneous Dual-Band with PoE Access...
D-Link Wireless AC1200 Simultaneous Dual-Band with PoE Access Point
£85.22
22 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Harness the power of Wireless AC, enjoying wireless speeds of up to 867+300 Mbps1 , perfect for highdemand business applications
  • Load balancing with band steering to provide a faster and more stable wireless connection
  • Maintain a secure network with a range of features including WPA/WPA2, Wireless LAN segmentation and VLAN support
  • Configure to use as an access point, a wireless distribution system (WDS) with access point, a WDS/ bridge, or a wireless client
  • Type: Radio access point
  • Connectivity: Wireless
  • Speed: 1200Mbps
  • Protocol: IEEE 802.11a, IEEE 802.11ac (draft), IEEE 802.11b, IEEE 802.11g + 1 more
  • Compatibility: PC
Product codes
The DAP-2660 utilizes the cutting-edge speed of Wireless AC technology to give businesses the Next Generation Wireless Network. Combining Dual-Band Wireless AC1200 with an aesthetical design, the DAP-2660 can be deployed in any environment giving great wireless coverage without drawing attention to itself.
Product Description D-Link DAP-2660 - radio access point
Device Type Radio access point
Form Factor External
Data Link Protocol IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft)
Frequency Band 2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported PoE
Dimensions (WxDxH) 17 cm x 17 cm x 2.8 cm
Weight 316 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link Wireless AC1200...
£85.22
