D-Link Wireless AC1750 Simultaneous Dual-Band PoE Access Point
£197.98
Delivery:
Key features
  • Harness the power of Wireless AC, enjoying wireless speeds of up to 1300+450 Mbps , perfect for highdemand business applications
  • Load balancing with band steering to provide more stable and faster wireless connection
  • Maintain a secure network with a range of features including WPA/WPA2, Wireless LAN segmentation, and VLAN support
  • Configure to use as an Access Point, a Wireless Distribution System (WDS) with Access Point, a WDS/ Bridge, or a Wireless Client
Product codes
The DAP-2695 is a versatile, high power outdoor access point designed for harsh conditions, it is the ideal solution for creating hot spots or extending wireless networks outdoors.
Product Description D-Link AirPremier DAP-2695 - radio access point
Device Type Radio access point
Form Factor External - indoor
Data Link Protocol IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft)
Frequency Band 2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported PoE+
Dimensions (WxDxH) 19 cm x 19.88 cm x 3.65 cm
Weight 1.14 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link Wireless AC1750...
£197.98
