We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The DAP-2680 Wireless AC1750 Wave 2 Dual-Band PoE Access Point is designed to support small to medium business or enterprise environments by providing network administrators with secure and manageable dual-band wireless LAN options, and utilizing the cutting-edge speed of Wireless AC.
Product Description | D-Link DAP-2680 - radio access point - Wi-Fi 5 | Device Type | Radio access point | Form Factor | External | Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2 | Frequency Band | 2.4 GHz, 5 GHz | Power Over Ethernet (PoE) Supported | PoE+ | Dimensions (WxDxH) | 19 cm x 19 cm x 4.48 cm | Weight | 580 g |
General | |
Width | 19 cm |
Depth | 19 cm |
Height | 4.48 cm |
Weight | 580 g |
Networking | |
Connectivity Technology | Wireless |
Data Transfer Rate | 1750 Mbps |
Remote Management Protocol | Telnet, SNMP 3, SNMP 2c, HTTP, SSH |
Wi-Fi Rating | AC1750 |
Status Indicators | Power, status |
Features | LDAP support, VLAN support, MAC address filtering, Wireless Distribution System (WDS) support, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Network Access Protection (NAP), ceiling mountable, Energy-Efficient Ethernet (EEE) |
Encryption Algorithm | 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise |
Authentication Method | RADIUS, Radio Service Set ID (SSID) |
Compliant Standards | IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac Wave 2 |
Aerial | |
Antenna | Internal |
Antenna Qty | 6 |
Expansion / Connectivity | |
Interfaces | 1 x 1000Base-T (PoE+) - RJ-45 |
Miscellaneous | |
MTBF | 30,000 hours |
Compliant Standards | UL, FCC |
Power | |
Power Device | External power adapter (not included) |
Power Consumption Operational | 17.53 Watt |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
