The D-Link DWL Wave 2 Series Unified AC Wave 2 Wireless Access Points are specially designed for small to medium businesses or enterprises, providing unparalleled bandwidth and flexibility for administrators looking to deploy a medium to large scale Wi-Fi network with manageable dual-band wireless LAN possibilities and utilizing the outstanding speed of Wireless AC Wave 2. Not only can it operate in standalone mode, the D-Link Unified AC Wave 2 Wireless Access Points can also be centrally managed by D-Link Unified Wireless Controllers. Highly-manageable and capable of blazing speeds, the Unified AC Wave 2 Wireless Access Points integrate seamlessly into any existing network infrastructure and can be easily scaled to meet future demands.
Product Description | D-Link Unified AC Wave 2 DWL-8620APE - radio access point - Wi-Fi 5 | Device Type | Radio access point | Form Factor | External | Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2 | Frequency Band | 2.4 GHz (1 band) / 5 GHz (2 bands) | Capacity | SSIDs total: 32 , SSIDs per radio: 16 | Power | DC 12 V | Dimensions (WxDxH) | 22 cm x 22 cm x 4.7 cm | Weight | 920 g |
General | |
Width | 22 cm |
Depth | 22 cm |
Height | 4.7 cm |
Weight | 920 g |
Networking | |
Connectivity Technology | Wireless |
Remote Management Protocol | SNMP 1, Telnet, SNMP 3, SNMP 2c, SSH, CLI |
Features | Power over Ethernet (PoE), VLAN support, MAC address filtering, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), rogue access point detection, Link Aggregation, band steering, dual band, Fast Roaming, Airtime Fairness, 4x4 MU-MIMO technology, Station Isolation |
Encryption Algorithm | AES, TKIP, WPA, WPA2 |
Compliant Standards | IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.3at, IEEE 802.11ac Wave 2 |
Aerial | |
Antenna | External detachable |
Directivity | Omni-directional |
Expansion / Connectivity | |
Interfaces | 1 x 1000Base-T (PoE) - RJ-45 , 1 x 1000Base-T - RJ-45 , 1 x console - RJ-45 |
Miscellaneous | |
MTBF | 460,185 hours |
Compliant Standards | BSMI, EN 61000-3-2, EN 61000-3-3, EN55024, CB, IC, FCC, EN 60601-1-2, NCC, RCM, EN 300 328, EN 301 489-1, EN 301 893, EN 55032, EN 301 489-17, cUL+UL |
Power | |
Power Device | External power adapter |
Voltage Required | DC 12 V |
Power Consumption Operational | 24.24 Watt |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
