D-Link Wireless N 150 High Gain USB Adapter
£17.07
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Rotatable high-gain antenna allows for enhanced wireless reception and reliable connection
  • Wireless N 150 technology gives you increased speed and range over 802.11g/b
  • Use the Quick Setup Wizard and Wi-Fi Protected Setup (WPS) for easy, automatic connection to a wireless network
  • Wired / Wireless: Wireless
  • Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
  • Form Factor: External
  • Compatibility: PC
  • Type: Network adapter
Product codes
Connect to a high-speed wireless network with D-Link's Wireless N 150 High-Gain USB Adapter. This adapter uses Wireless N 150 technology to provide increased speed and range over the wireless standard, giving you a faster, more reliable connection, making it ideal for email, web browsing and file sharing in the home.
Product Description D-Link Wireless N DWA-127 - network adapter
Device Type Network adapter
Form Factor External
Interface (Bus) Type USB 2.0
Dimensions (WxDxH) 1.5 cm x 1.4 cm x 21 cm
Data Link Protocol 802.11b/g/n
Frequency Band 2.4 GHz
Compliant Standards IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, USB 2.0, IEEE 802.11n
System Requirements Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP SP3
Designed For D-Link DIR-600
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link Wireless N 150...
£17.07
