We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The xStack DGS-3420 series of next generation Layer 2+ Gigabit switches delivers performance, flexibility, security, multi-layer QoS, and accessibility, along with redundant power solutions for SMBs and enterprises. With high Gigabit port densities, Gigabit SFP, 10-Gigabit SFP+ support, and advanced software solutions, these switches can act as either departmental access layer devices or aggregation switches to form a multilevel network structured with backbone and centralized high-speed servers.
Product Description | D-Link xStack DGS-3420-28PC - switch - 24 ports - Managed - rack-mountable | Device Type | Switch - 24 ports - Managed - stackable | Enclosure Type | Rack-mountable 1U | Subtype | Gigabit Ethernet | Ports | 24 x 10/100/1000 + 4 x combo Gigabit SFP + 4 x 10 Gigabit SFP+ | Power Over Ethernet (PoE) | PoE | Performance | Switching capacity: 128 Gbps , Forwarding performance: 95.24 Mpps | MAC Address Table Size | 16K entries | Jumbo Frame Support | 12KB | Routing Protocol | RIP-1, RIP-2, static IP routing, RIPng | Remote Management Protocol | SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, CLI | Features | Flow control, full duplex capability, power over Ethernet (PoE), BOOTP support, ARP support, VLAN support, IGMP snooping, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, sFlow, Spanning Tree Protocol (STP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, MLD snooping, Safeguard Engine, bandwidth control, Link Aggregation Control Protocol (LACP) | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ah, IEEE 802.1v, IEEE 802.1ak, IEEE 802.3at, IEEE 802.1AX | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 44.1 cm x 38 cm x 4.4 cm |
General | |
Encryption Algorithm | SSL, SSL 3.0, SSL 2.0 |
Authentication Method | Secure Shell (SSH), RADIUS, Secure Shell v.2 (SSH2) |
RAM | 256 MB |
Flash Memory | 128 MB |
Status Indicators | Power, RPS (Redundant Power Supply), PoE, link/activity, console |
Expansion / Connectivity | |
Interfaces | 24 x 1000Base-T RJ-45 , 1 x console RJ-45 management , 4 x SFP+ , 4 x SFP (mini-GBIC) |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Features | Redundant Power System (RPS) connector |
Miscellaneous | |
MTBF | 20,619 hours |
Compliant Standards | UL, VCCI, C-Tick, cUL, CB, FCC, RoHS |
Dimensions & Weight | |
Width | 44.1 cm |
Depth | 38 cm |
Height | 4.4 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 10 - 90% |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 90% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
