Get more productive than ever. Dell 19 monitor P1917S brings greater productivity to the workplace with added user comfort and convenience.
Product Description | Dell P1917S - LED monitor - 19" | Device Type | LED-backlit LCD monitor - 19" | Energy Class | Class A+ | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 5:4 | Native Resolution | 1280 x 1024 at 60 Hz | Pixel Pitch | 0.293 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 6 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Colour | Black | Dimensions (WxDxH) - with stand | 40.6 cm x 18 cm x 36.9 cm | Weight | 5.13 kg | Environmental Standards | ENERGY STAR Qualified | Designed For | Latitude 7400 2-in-1 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 19" |
Viewable Size | 19" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Ultra wide viewing angle, Flicker Free technology, Premium Panel Guarantee, Dell ComfortView |
Colour | Black |
Dimensions (WxDxH) | 40.6 cm x 18 cm x 36.9 cm - with stand |
Weight | 5.13 kg |
Connectivity | |
Interfaces | HDMI , DisplayPort , VGA , USB 3.0 , USB 2.0 |
Mechanical | |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable |
Security Slot Type | Kensington security slot |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 14 Watt |
Power Consumption Stand by | 0.3 Watt |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Compatibility Information | |
Designed For | Dell Latitude 7400 2-in-1 |
