Collaborate like you're there on a 27-inch QHD monitor with an integrated 5MP camera, dual 5W speakers and a dedicated Microsoft Teams button.
Product Description | Dell 27 Video Conferencing Monitor C2722DE - LED monitor - 27" - with 3-year Basic Advanced Exchange | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class F | Power Consumption (On mode) | 22.8 W | Features | 5.0 megapixel camera, USB 3.2 Gen 1/USB-C hub, USB PD 90 Watt | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | WQHD 2560 x 1440 at 60 Hz | Pixel Pitch | 0.2331 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 | Response Time | 6 ms (grey-to-grey fast), 8 ms (grey-to-grey normal) | Colour Support | 16.7 million colours | Colour Gamut | 99% sRGB | Input Connectors | HDMI, DisplayPort, USB-C | Built-in Ethernet | Yes | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare 3H hardness | Voltage | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) - with stand | 61.234 cm x 23 cm x 44.557 cm | Weight | 8.8 kg | Environmental Standards | TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified | Compliant Standards | RoHS, DisplayPort 1.2, BFR-free, DisplayPort 1.4, HDCP 1.4, PVC-free | Bundled Services | 3 years Advanced Exchange Basic Warranty | Designed For | Latitude 5320, 5520; Precision 7560; XPS 15 9510 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Built-in Devices | 5.0 megapixel camera, USB 3.2 Gen 1/USB-C hub |
USB Power Delivery | 90 Watt |
Panel Type | IPS |
Pixel Per Inch | 108.79 |
Vertical Refresh Rate | 56 - 76 Hz |
Horizontal Refresh Rate | 30 - 90 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Flicker Free technology, Mercury free, arsenic-free glass, 3-sided bezeless, 99% sRGB colour gamut |
Dimensions (WxDxH) | 61.234 cm x 23 cm x 44.557 cm - with stand |
Weight | 8.8 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 5 Watt |
Connectivity | |
Interfaces | HDMI (HDCP 1.4) , DisplayPort 1.4 (HDCP 1.4) , USB-C 3.2 Gen 1 upstream/DisplayPort 1.4 Alt Mode (power up to 90W) , USB 3.2 Gen 1 upstream (Type B) , USB-C 3.2 Gen 1 downstream (power up to 15W) , 2 x USB 3.2 Gen 1 downstream , USB 3.2 Gen 1 downstream with Battery Charging 1.2 , Headphones , Network (RJ-45) , DisplayPort output (MST) |
Mechanical | |
Tilt Angle | -5/+21 |
Swivel Angle | 90 |
Rotation Angle | 180 |
Height Adjustment | 120 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support, cable management panel |
Cables Included | 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C cable - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable - USB Type A to B - 1.8 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 22.8 kWh/1000h |
Power Consumption (Typical) | 26.5 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.2 Watt |
Software / System Requirements | |
Included Software | Dell Display Manager |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.234 cm - depth: 23 cm - height: 44.557 cm - weight: 8.8 kg , Without stand - width: 61.234 cm - depth: 5.393 cm - height: 42.543 cm - weight: 5.74 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 9.21 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8, TCO Certified Edge Displays |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
Compatibility Information | |
Designed For | Dell Latitude 5320, 5520 , Dell Precision 7560 , Dell XPS 15 9510 |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
