Space saving, the Dell Dual Monitor Stand - MDS19 mounts up to two 27-inch monitors, providing the screen real estate you need to be most productive. The dual monitor stand frees up the workspace in front of you for writing and referencing. The round cable management slot neatly channels cables within its stand, routing them along the curved bar with cable clips keeping the cables intact and hidden from view. Each monitor panel is fully adjustable, allowing you to set the height, tilt, pivot, and swivel to suit your viewing comfort. The stand's tool-free installation feature makes it easy to securely snap Dell UltraSharp and P-series monitors with Quick Release into place without the need for screws. It also supports Dell E-series monitors and other 19" to 27" 100 mm x 100 mm standard VESA compatible monitors.
Product Description | Dell MDS19 Dual Monitor Stand - stand - for 2 monitors | Product Type | Stand | Dimensions (WxDxH) | 57.7 cm x 24.9 cm | Tilt | -5° to 24° | Lift | 13 cm | Rotation | -90° to 90° | Swivel | -10° to 15° | Adjustments | Tilt, swivel, rotation, lift | Recommended Use | 2 monitors | Recommended Display Size | 19"-27" | VESA Mounting Interface | Yes | Max Mounting Pattern Size | 100 x 100 mm | Max Load Weight | 6 kg | Package Content | Cable clips, round cable slot |
General | |
Width | 57.7 cm |
Depth | 24.9 cm |
AV Furniture | |
Type | Stand |
Cable Management | Cable clips on the bar, round cable slot |
Tilt | -5° to 24° |
Lift | 13 cm |
Min Load Weight | 2.2 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
