Dell E1715S 17" 1280x1024 5ms VGA DisplayPort LED Monitor
£96.21
Delivery:
Standard: 1-3 working days
Key features
  • Essential features
  • Responsible design
  • A great fit
  • Simple connections
  • Tilt adjustment
  • Diagonal Size: 17in
  • Max Resolution: 1280 x 1024
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DisplayPort, VGA (HD-15)
Product codes
The Dell 17 monitor E1715S is your smart choice for reliability and essential features that can help drive productivity. Add the E1715S to your workplace for a great viewing experience in just about any setting.
Product Description Dell E1715S - LED monitor - 17" - with 3-years Premium Panel Exchange service
Device Type LED-backlit LCD monitor - 17"
Panel Type TN
Native Resolution 1280 x 1024 at 60 Hz
Pixel Pitch 0.264 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms (black-to-white)
Colour Support 16.7 million colours
Input Connectors VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Black
Dimensions (WxDxH) - with stand 37.45 cm x 16.55 cm x 38.95 cm
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, VESA EDID, DDC/CI, RoHS, CECP
Bundled with 3-years Premium Panel Exchange service
Accessories
Accessories
Other bundles
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Dell E1715S 17" 1280x1...
£96.21
