Dell E1916H 18.5" 1920x1080 5ms VGA DisplayPort LED Monitor
£77.31
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Advanced screen performance
  • Plug and view
  • Mounting possibility
  • Tilt at will
  • Convenient controls
  • Environmentally friendly materials
  • Diagonal Size: 19in
  • Max Resolution: 1366 x 768
  • Response Time: 5ms
  • Interfaces: DisplayPort, VGA (HD-15)
  • Stock Status: In Stock
Product codes
A reliable and affordable 18.5-inch monitor with essential features that meets everyday office demands. It features HD quality display with VESA-mount compatibility and tilt options, as well as VGA and DisplayPort connectivity. It also saves energy with power-efficient features.
Product Description Dell E1916H - LED monitor - 19" - with 3-Years Advance Exchange Service
Device Type LED-backlit LCD monitor - 19"
Panel Type TN
Aspect Ratio 16:9
Native Resolution 1366 x 768 at 60 Hz
Pixel Pitch 0.3 mm
Brightness 200 cd/m²
Contrast Ratio 600:1
Response Time 5 ms (black-to-white)
Colour Support 16.7 million colours
Input Connectors VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Black
Dimensions (WxDxH) - with stand 44.54 cm x 16.7 cm x 35.9 cm
Weight 2.72 kg
Microsoft Certification Compatible with Windows 7
Environmental Standards TCO Certified ENERGY STAR Qualified
Compliant Standards DDC/CI, RoHS, CECP
Bundled with 3-Years Advance Exchange Service
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Dell E1916H 18.5" 1920...
£77.31
