We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The essentials you need to be more productive. Get a wide viewing angle while saving desk space. This 21.5-inch Full HD monitor features height adjustability, built-in speakers and an eco-conscious design.
Product Description | Dell E2222HS - LED monitor - Full HD (1080p) - 22" | Device Type | LED-backlit LCD monitor - 22" | Energy Class | Class D | Power Consumption (On mode) | 12 W | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.249 mm | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 / 3000:1 (dynamic) | Response Time | 5 ms (grey-to-grey), 10 ms (typical) | Colour Support | 16.7 million colours | Colour Gamut | 72% (CIE 1931), 83% (CIE 1976) | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 100-240 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 50.426 cm x 18.728 cm x 35.417 cm | Weight | 3.9 kg | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Gold | Bundled Services | 3 years Advanced Exchange Basic Warranty | Designed For | OptiPlex 3090; Vostro 14 5410, 15 5510 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Panel Type | VA |
Pixel Per Inch | 103 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Flicker Free technology, Dell ComfortView |
Colour | Black |
Dimensions (WxDxH) | 50.426 cm x 18.728 cm x 35.417 cm - with stand |
Weight | 3.9 kg |
Audio | |
Type | Speakers |
Connectivity | |
Interfaces | HDMI (HDCP 1.2) , DisplayPort 1.2 , VGA |
Mechanical | |
Tilt Angle | -5/+21 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support |
Included Accessories | VESA screw cover |
Cables Included | 1 x HDMI cable |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 12.1 kWh/1000h |
Power Consumption (Typical) | 12.13 Watt |
Power Consumption (Max) | 21 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption Sleep | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
On / Off Switch | Yes |
Software / System Requirements | |
Included Software | Dell Display Manager |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 50.426 cm - depth: 18.728 cm - height: 35.417 cm - weight: 3.9 kg , Without stand - weight: 2.36 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 5.11 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
EPEAT Compliant | EPEAT Gold |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Compatibility Information | |
Designed For | Dell OptiPlex 3090 , Dell Vostro 14 5410, 15 5510 |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
