Dell E2417H 24" 1920 x 1080 8ms DP VGA LED Monitor
£137.44
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Maximize workplace productivity with a monitor designed to meet your business needs
  • Create a workspace that fits your desired specifications
Product codes
View your applications, spreadsheets and more with incredible clarity. Optimize eye comfort and reduce harmful blue light emissions with ComfortView and a flicker free screen. See consistent colors across an ultrawide viewing angle. Easily access buttons for power, brightness, contrast and customizable preset modes on the monitor's front panel. Work comfortably by tilting the monitor 5° forward or 21° backward. The monitor is compatible with most legacy and current PCs via VGA and DisplayPort connectivity.
Dell E2417H - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
56.26 cm x 17.99 cm x 42.51 cm
3.97 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC/CI, RoHS, TCO Displays, EDID compatible
Bundled Services
3 years Advanced Exchange Service
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Dell E2417H 24" 1920 x...
£137.44
