General |
Display Type |
LED-backlit LCD monitor / TFT active matrix |
Diagonal Size |
24" |
Viewable Size |
23.8" |
Panel Type |
IPS |
Aspect Ratio |
16:9 |
Native Resolution |
Full HD (1080p) 1920 x 1080 at 60 Hz |
Pixel Pitch |
0.275 mm |
Pixel Per Inch |
93 |
Brightness |
250 cd/m² |
Contrast Ratio |
1000:1 |
Colour Support |
16.7 million colours |
Response Time |
8 ms (grey-to-grey) |
Vertical Refresh Rate |
50 - 76 Hz |
Horizontal Refresh Rate |
30 - 83 kHz |
Horizontal Viewing Angle |
178 |
Vertical Viewing Angle |
178 |
Screen Coating |
Anti-glare, 3H Hard Coating |
Backlight Technology |
WLED |
OSD Languages |
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese |
Features |
LED edgelight system, 72% NTSC (CIE 1931) colour gamut, Flicker Free technology, BFR/PVC-free, Mercury free, arsenic-free glass, Dell ComfortView, 87% NTSC (CIE 1976) colour gamut |
Colour |
Black |
Dimensions (WxDxH) |
56.26 cm x 17.99 cm x 42.51 cm - with stand |
Weight |
3.97 kg |
Connectivity |
Interfaces |
DisplayPort , VGA |
Mechanical |
Display Position Adjustments |
Tilt |
Tilt Angle |
-5/+21 |
VESA Mounting Interface |
100 x 100 mm |
Miscellaneous |
Features |
Security lock slot (cable lock sold separately), LED indicator, integrated cable management, VESA interface support, Dell Soundbar mounting slots |
Included Accessories |
VESA screw cover |
Cables Included |
1 x DisplayPort cable |
Compliant Standards |
Plug and Play, DDC/CI, RoHS, EDID compatible |
Power |
Voltage Required |
AC 120/230 V (50/60 Hz) |
Power Consumption Operational |
22 Watt |
Power Consumption Stand by |
0.3 Watt |
Power Consumption Sleep |
0.3 Watt |
Power Consumption (Off Mode) |
0.3 Watt |
Dimensions & Weight |
Dimensions & Weight Details |
With stand - width: 56.26 cm - depth: 17.99 cm - height: 42.51 cm - weight: 3.97 kg , Without stand - width: 56.26 cm - depth: 5.35 cm - height: 33.31 cm - weight: 3.28 kg |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Manufacturer Warranty |
Service & Support |
Limited warranty - 3 years |
Bundled Services |
3 years Advanced Exchange Service |
Environmental Parameters |
Min Operating Temperature |
0 °C |
Max Operating Temperature |
40 °C |
Humidity Range Operating |
10 - 80% (non-condensing) |
Compatibility Information |
Designed For |
Dell Latitude 7400 2-in-1 |
