Dell E2417H 24" 1920 x 1080 8ms DP VGA LED Monitor
£127.48
28 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Maximize workplace productivity with a monitor designed to meet your business needs
  • Create a workspace that fits your desired specifications
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 8ms
  • Speakers: None
  • Interfaces: DisplayPort, VGA (HD-15)
Product codes
View your applications, spreadsheets and more with incredible clarity. Optimize eye comfort and reduce harmful blue light emissions with ComfortView and a flicker free screen. See consistent colors across an ultrawide viewing angle. Easily access buttons for power, brightness, contrast and customizable preset modes on the monitor's front panel. Work comfortably by tilting the monitor 5° forward or 21° backward. The monitor is compatible with most legacy and current PCs via VGA and DisplayPort connectivity.
Product Description Dell E2417H - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.275 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 8 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Black
Dimensions (WxDxH) - with stand 56.26 cm x 17.99 cm x 42.51 cm
Weight 3.97 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, DDC/CI, RoHS, EDID compatible
Bundled Services 3 years Advanced Exchange Service
Designed For Latitude 7400 2-in-1
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Dell E2417H 24" 1920 x...
£127.48
