We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
This 23.8-inch Full HD monitor features a wide viewing angle, HDMI connectivity and an eco-conscious design.
Product Description | Dell E2422HN - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class E | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.2745 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal) | Colour Support | 16.7 million colours | Colour Gamut | 72% (CIE 1931), 83% (CIE 1976) | Input Connectors | HDMI, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare 3H hardness | Voltage | AC 100-240 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 55.264 cm x 17.1 cm x 42.035 cm | Weight | 3.55 kg | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Gold | Compliant Standards | RoHS, NFPA 99, BFR-free, PVC-free, Mercury-free | Bundled Services | 3 years Advanced Exchange Service | Designed For | Vostro 14 5410, 15 3510, 15 5510 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Viewable Size | 23.8" |
Panel Type | IPS |
Pixel Per Inch | 93 |
Vertical Refresh Rate | 50 - 75 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | LED edgelight system, Mercury free, arsenic-free glass |
Colour | Black |
Dimensions (WxDxH) | 55.264 cm x 17.1 cm x 42.035 cm - with stand |
Weight | 3.55 kg |
Connectivity | |
Interfaces | HDMI , VGA |
Mechanical | |
Tilt Angle | -5/+21 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support |
Included Accessories | VESA screw cover |
Cables Included | 1 x HDMI cable |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 16 kWh/1000h |
Power Consumption (Typical) | 16 Watt |
Power Consumption (Max) | 28 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
Included Software | Dell Display Manager |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 55.264 cm - depth: 17.1 cm - height: 42.035 cm - weight: 3.55 kg , Without stand - width: 55.264 cm - depth: 4.969 cm - height: 331.61 cm - weight: 3.2 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 5.5 kg |
Sustainability Information | |
TCO Certified | TCO Certified Displays 8 |
EPEAT Compliant | EPEAT Gold |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 8.0 |
Manufacturer Warranty | |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
Compatibility Information | |
Designed For | Dell Vostro 14 5410, 15 3510, 15 5510 |
