General |
Product Type |
Notebook |
Operating System |
Windows 10 Pro 64-bit Edition |
Processor / Chipset |
CPU |
Intel Core i5 (8th Gen) 8265U / 1.6 GHz |
Max Turbo Speed |
3.9 GHz |
Number of Cores |
Quad-Core |
Cache |
6 MB |
64-bit Computing |
Yes |
Features |
Intel Turbo Boost Technology 2.0 |
Memory |
RAM |
4 GB (1 x 4 GB) |
Max RAM Supported |
64 GB |
Technology |
DDR4 SDRAM - non-ECC |
Speed |
2400 MHz |
Rated Speed |
2666 MHz |
Form Factor |
SO-DIMM 260-pin |
Slots Qty |
2 |
Empty Slots |
1 |
Storage |
Main Storage |
1 TB HDD SATA / 5400 rpm |
Display |
Type |
15.6" |
Resolution |
1920 x 1080 (Full HD) |
Widescreen |
Yes |
Image Brightness |
220 cd/m² |
Features |
Anti-glare, WideView, 60 Hz refresh rate, ±40° horizontal viewing angle, +10/-30 vertical viewing angle |
Audio & Video |
Graphics Processor |
Intel UHD Graphics 620 |
Memory Allocation Technology |
Shared Video Memory (UMA) |
Camera |
Yes - 1280 x 720 |
Resolution |
0.92 Megapixel |
Video Resolutions |
1280 x 720 |
Frame Rate |
60 frames per second |
Camera Features |
86.7 degrees |
Sound |
Stereo speakers, dual array microphone |
Codec |
Realtek ALC3204 |
Input |
Type |
Keyboard, touchpad |
Keyboard Backlight |
Yes |
Features |
Multi-touch touchpad |
Communications |
Wireless |
802.11a/b/g/n/ac Wave 2, Bluetooth 5.0 |
Wireless Controller |
Intel Wireless-AC 9560 |
Network Interface |
Gigabit Ethernet |
Ethernet Controller |
Realtek RTL8111H |
Features |
Wake-on-LAN (WOL) |
Battery |
Technology |
4-cell Lithium Ion |
Capacity |
56 Wh |
AC Adapter |
Input |
AC 120/230 V (50/60 Hz) |
Output |
65 Watt, 19.5 V |
Connections & Expansion |
Interfaces |
USB 3.1 Gen 1 , USB 3.1 Gen 1 (PowerShare) , USB-C 3.1 Gen 1/DisplayPort (Power Delivery) , USB 2.0 , HDMI , VGA , LAN , Headphone/microphone combo jack |
Software |
Software Included |
Microsoft Office (Trial), Dell Precision Optimizer |
Miscellaneous |
Colour |
Black |
Security |
Trusted Platform Module (TPM 2.0) Security Chip |
Features |
ExpressCharge, noise reducing microphone |
Theft/Intrusion Protection |
Security lock slot (cable lock sold separately) |
Security Slot Type |
Noble Wedge security slot |
Included Accessories |
Power adapter |
Pricing Type |
Build To Stock (BTS) |
Dimensions & Weight |
Dimensions (WxDxH) |
37.866 cm x 25.52 cm x 1.8 cm |
Weight |
2.15 kg |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Manufacturer Warranty |
Service & Support |
Limited warranty - 1 year - on-site |
Environmental Parameters |
Min Operating Temperature |
0 °C |
Max Operating Temperature |
35 °C |
Humidity Range Operating |
10 - 80% (non-condensing) |
Shock Tolerance (operating) |
105 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) |
40 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) |
0.26 g @ RMS (random) |
Vibration Tolerance (non-operating) |
1.37 g @ RMS (random) |
