An easily managed laptop with superior security features critical for small and growing businesses, all in a durable, reliable and sleek design.
Product Description | Dell Latitude 3590 - 15.6" - Core i5 7200U - 4 GB RAM - 500 GB HDD | Product Type | Notebook | Operating System | Win 10 Pro 64-bit - Multilingual User Interface (MUI) | Processor | Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache | Memory | 4 GB DDR4 (1 x 4 GB) | Storage | 500 GB HDD / 7200 rpm | Optical Drive | No optical drive | Display | 15.6" WLED 1366 x 768 / HD | Graphics | Intel HD Graphics 620 | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet | Battery | 4-cell | Security | Trusted Platform Module (TPM 2.0) Security Chip | Colour | Black | Dimensions (WxDxH) | 38 cm x 25.8 cm x 2.27 cm | Weight | 2.02 kg | Pricing Type | Build To Stock (BTS) | Manufacturer Warranty | Limited warranty - 1 year - on-site |
General | |
Operating System | Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI) |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7200U / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 4 GB (1 x 4 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz |
Rated Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 500 GB HDD SATA / 7200 rpm |
Display | |
Type | 15.6" |
LCD Backlight Technology | WLED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 220 cd/m² |
Features | Anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes - HD |
Resolution | 0.92 Megapixel |
Image Sensor Type | CMOS |
Video Resolutions | 1280x720 |
Frame Rate | 30 frames per second |
Camera Features | Fixed focus |
Sound | Stereo speakers, dual array microphone |
Codec | Realtek ALC3246 |
Compliant Standards | High Definition Audio |
Audio Features | MaxxAudio Pro |
Input | |
Type | Keyboard, touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Wireless Controller | Qualcomm QCA61x4A - M.2 2230 |
Network Interface | Gigabit Ethernet |
Battery | |
Technology | 4-cell lithium polymer |
Capacity | 56 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt, 19.5 V, 3.34 A |
Connections & Expansion | |
Interfaces | USB 2.0 , USB-C 3.1 Gen 1 (PowerShare) , USB-C/DisplayPort (Power Delivery) , HDMI , VGA , LAN , Headphone/microphone combo jack |
Memory Card Reader | Yes (SD Card) |
Software | |
Software Included | Microsoft Office (Trial), McAfee (30 days trial) |
Miscellaneous | |
Colour | Black |
Features | ExpressCharge, MU-MIMO technology |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Noble Wedge security slot |
Included Accessories | Power adapter |
Compliant Standards | FIPS 140-2 |
Dimensions & Weight | |
Weight | 2.02 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - on-site |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% |
