General |
Display Type |
LED-backlit LCD monitor / TFT active matrix |
Diagonal Size |
24" |
Viewable Size |
24" |
Built-in Devices |
USB 2.0 hub |
Panel Type |
IPS |
Aspect Ratio |
16:10 |
Native Resolution |
1920 x 1200 at 60 Hz |
Pixel Pitch |
0.27 mm |
Brightness |
300 cd/m² |
Contrast Ratio |
1000:1 / 2000000:1 (dynamic) |
Colour Support |
16.7 million colours |
Response Time |
8 ms (grey-to-grey) |
Vertical Refresh Rate |
50 - 61 Hz |
Horizontal Refresh Rate |
30 - 83 kHz |
Horizontal Viewing Angle |
178 |
Vertical Viewing Angle |
178 |
Screen Coating |
Anti-glare, 3H Hard Coating |
Backlight Technology |
LED backlight |
Colour Temperature |
5000K, 10000K |
OSD Languages |
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese |
Features |
72% (CIE 1931) colour gamut, 82% (CIE 1976) colour gamut, LED edgelight system, PowerNap, Dynamic Dimming, stand lock, Energy Saver, Transition Minimised Differential Signaling (TMDS) technology |
Colour |
Black |
Dimensions (WxDxH) |
55.6 cm x 18.03 cm x 39.85 cm - with stand |
Weight |
5.73 kg |
Connectivity |
Interfaces |
VGA , DVI-D , DisplayPort , USB 2.0 upstream (Type B) , 4 x USB 2.0 downstream (Type A) |
Mechanical |
Display Position Adjustments |
Height, pivot (rotation), swivel, tilt |
Tilt Angle |
-4/+21 |
Swivel Angle |
90 |
Rotation Angle |
90 |
Height Adjustment |
115 mm |
VESA Mounting Interface |
100 x 100 mm |
Miscellaneous |
Features |
Security lock slot (cable lock sold separately), Dell Energy Smart, LED indicator, integrated cable management, portrait / landscape mode, VESA interface support, Dell Soundbar mounting slots |
Included Accessories |
Stand |
Cables Included |
1 x DVI cable , 1 x VGA cable - VGA to VGA , 1 x USB cable - USB Type A to B |
Mounting Kit |
Optional |
Compliant Standards |
Plug and Play, DDC/CI, EDID compatible |
Security Slot Type |
Kensington security slot |
Power |
Voltage Required |
AC 120/230 V (50/60 Hz) |
Power Consumption Operational |
29 Watt |
Power Consumption (Off Mode) |
0.5 Watt |
Software / System Requirements |
Included Software |
Drivers & Utilities, PowerNap |
Dimensions & Weight |
Dimensions & Weight Details |
Without stand - width: 55.6 cm - depth: 6.49 cm - height: 36.16 cm - weight: 3.97 kg , With stand - width: 55.6 cm - depth: 18.03 cm - height: 39.85 cm - weight: 5.73 kg |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Manufacturer Warranty |
Service & Support |
Limited warranty - 3 years |
Bundled Services |
3 years Advanced Exchange Basic Warranty |
Environmental Parameters |
Min Operating Temperature |
0 °C |
Max Operating Temperature |
40 °C |
Humidity Range Operating |
10 - 80% (non-condensing) |
