Dell Optiplex 5050 SFF Core i5-7500 8GB 500GB Windows 10 Pro
Key features
  • Powerful productivity and expandability
  • A conveniently compact, innovative design
  • Powerful performance. Smart solutions
  • Trusted reliability. Serious security
Product codes
Expandable tower and small form factor desktops with business-critical features companies need with the space to add additional peripherals.
Stay flexible: With full-power features in a smart, dual orientation design, the OptiPlex 5050 lets you maximize your work environment. Towers can be setup on or under your desk, while the small form factor can be combines with the new OptiPlex Small Form Factor All-in-One stand to create versatile, flexible solutions for any office situation.
Secure and unified: These optional cable covers reduce clutter, prevent access to the ports and cables in the back of the system and seamlessly match the OptiPlex's elegant design, so your setup looks unified and stays protected.
Easy access: With a tool-less design and a simple removable side panel, you have easy access to key system components such as drives and memory so your system can be updated, remaining viable for years to come.
Power your success: Intel 7th Gen processors make this the fastest OptiPlex yet.
Smooth, speedy performance: Upgraded 2400MHz DDR4 is the fastest and most efficient memory available, so you can work with lags or crashes.
Connect with ease: Two display ports, native 3 display support, and HDMI with optional VGA, as well as legacy ports provide ample connection to your devices and networks.
Always up to date: Every OptiPlex 5050 is available with Dell Command Suite, making driver, BIOS, and firmware updates easier. These free tools allow flexible and automated BIOS or system configurations for your company, allowing you to manage your fleet easily and securely every time.
Work remotely, with confidence: Optional Intel Systems Management allows for remote and advanced out of band management capabilities for increased productivity and lower risk.
Dell OptiPlex 5050 - SFF - Core i5 7500 3.4 GHz - 8 GB - 500 GB
Personal computer - small form factor
1 x Intel Core i5 (7th Gen) 7500 / 3.4 GHz (3.8 GHz) (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-19200
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
Intel HD Graphics 630
GigE
OS Provided
Windows 10 Pro 64-bit Edition
29.2 cm x 9.26 cm x 29 cm
5.14 kg
Pricing Type
Build To Stock (BTS)
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - response time: next business day
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Dell Optiplex 5050 SFF...
