Dell OptiPlex MicroDual VESA Desktop to monitor mounting kit
Key features
  • Integrated cable management, back of a monitor mountable
Product codes
Mount your OptiPlex system on a movable display
The Dell OptiPlex Micro Dual VESA Mount is designed to hide your OptiPlex Micro PC behind a flexible, wall-mounted display arm (M8 Clamp Mount Arm/SKU A7832860 sold separately). In addition to keeping your OptiPlex system out of view, this mount allows the system to move and travel with the arm and display.
Create a more productive work environment
The Dell OptiPlex Micro Dual VESA Mount is ideal for collaborative work environments where users share a display. It's also a great choice for those who want the flexibility to stand while they work. The Dual VESA Mount gives OptiPlex users a customizable solution to fit their workflow without the hassle of wires running between the system and the display.
Hides the computer and unsightly cables
This design helps reduce office and desktop clutter by hiding the OptiPlex Micro system and associated cables behind your flat-panel display. Cabling is simplified by mounting the computer and monitor together, and the included power adaptor cover makes for an even cleaner workstation design.
An ideal companion for Dell displays
Designed and tested specifically for OptiPlex Micro systems, this mount integrates seamlessly with VESA compatible Dell displays and wall mounts.
What's in the Box
Dell Micro OptiPlex Dual VESA Mount.
Dell OptiPlex Micro Dual VESA Mount - desktop to monitor mounting kit
OptiPlex 3020 (micro), 3040 (micro), 7040 (micro), 9020 (micro)
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Dell OptiPlex MicroDua...
