Easily adjust your monitor to your desired angle, height, and position so you can enjoy great visuals across multiple monitors with no hassle.
Product Description | Dell P2018H - LED monitor - 20" | Device Type | LED-backlit LCD monitor - 20" | Energy Class | Class D | Energy Consumption per Year | 24 kWh | Power Consumption (On mode) | 9.7 W | Features | USB 3.0 hub | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | 1600 x 900 at 60 Hz | Pixel Pitch | 0.263 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 4000000:1 (dynamic) | Response Time | 5 ms (black-to-white) | Colour Support | 16.7 million colours | Colour Gamut | 72% (CIE 1931), 84% (CIE 1976) | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) - with stand | 46.15 cm x 18 cm x 33.88 cm | Weight | 4.3 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | CECP, CEL, TUV Rheinland Low Blue Light Certification, BFR-free, PVC-free | Bundled Services | 3 years Advanced Exchange Service |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 20" |
Viewable Size | 19.5" |
Built-in Devices | USB 3.0 hub |
Panel Type | TN |
Pixel Per Inch | 94 |
Vertical Refresh Rate | 56 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | WLED |
Features | PowerNap, stand lock, Flicker Free technology, BFR/PVC-free, Energy Gauge, Dell ComfortView |
Dimensions (WxDxH) | 46.15 cm x 18 cm x 33.88 cm - with stand |
Weight | 4.3 kg |
Connectivity | |
Interfaces | DisplayPort , HDMI , VGA , 2 x USB 2.0 downstream , USB 3.0 upstream , 2 x USB 3.0 downstream |
Mechanical | |
Tilt Angle | -5/+21 |
Swivel Angle | 90 |
Rotation Angle | 90 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support |
Cables Included | 1 x SuperSpeed USB cable , 1 x VGA cable , 1 x DisplayPort cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 9.7 kWh/1000h |
Power Consumption (Typical) | 14 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption Sleep | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 46.22 cm - depth: 18.03 cm - height: 33.78 cm - weight: 2.4 kg , Without stand - width: 46.15 cm - depth: 5 cm - height: 27.33 cm - weight: 2.4 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 6.13 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
