A better view from anywhere. Stay productive no matter where you work. Reduce harmful blue light with this sleek 21.5-inch FHD monitor featuring ComfortView Plus technology.
Product Description | Dell P2222H - LED monitor - Full HD (1080p) - 22" | Device Type | LED-backlit LCD monitor - 22" | Energy Class | Class D | Power Consumption (On mode) | 11.8 W | Features | USB 3.2 Gen 1 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.248 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal) | Colour Support | 16.7 million colours | Colour Gamut | 99% sRGB | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 100-240 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 48.726 cm x 17.957 cm x 48.199 cm | Weight | 4.83 kg | Environmental Standards | TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified | Compliant Standards | RoHS, NFPA 99, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free | Bundled Services | 3 years Advanced Exchange Service | Designed For | Latitude 5320, 5520; OptiPlex 3090; Precision 7560 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Built-in Devices | USB 3.2 Gen 1 hub |
Panel Type | IPS |
Pixel Per Inch | 102 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell ComfortView Plus, 99% sRGB colour gamut |
Colour | Black |
Dimensions (WxDxH) | 48.726 cm x 17.957 cm x 48.199 cm - with stand |
Weight | 4.83 kg |
Connectivity | |
Interfaces | DisplayPort , VGA , HDMI , USB 3.2 Gen 1 upstream , 4 x USB 3.2 Gen 1 downstream |
Mechanical | |
Tilt Angle | -5/+21 |
Swivel Angle | 90 |
Rotation Angle | 180 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support |
Cables Included | 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 11.8 kWh/1000h |
Power Consumption (Typical) | 11.8 Watt |
Power Consumption (Max) | 46 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption Sleep | 0.3 Watt |
Power Consumption (Off Mode) | 0.2 Watt |
Software / System Requirements | |
Included Software | Dell Display Manager |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 48.726 cm - depth: 17.957 cm - height: 36.4 cm - weight: 4.83 kg , Without stand - width: 48.726 cm - depth: 5.215 cm - height: 28.999 cm - weight: 2.82 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 6.37 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8, TCO Certified Edge Displays |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
Compatibility Information | |
Designed For | Dell Latitude 5320, 5520 , Dell OptiPlex 3090 , Dell Precision 7560 |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
