General |
Display Type |
LED-backlit LCD monitor / TFT active matrix |
Energy Class |
Class A+ |
Energy Consumption per Year |
23 kWh |
Power Consumption (On mode) |
16 W |
Diagonal Size |
23" |
Viewable Size |
23" |
Built-in Devices |
USB 3.0 hub |
Panel Type |
IPS |
Aspect Ratio |
16:9 |
Native Resolution |
Full HD (1080p) 1920 x 1080 at 60 Hz |
Pixel Pitch |
0.265 mm |
Pixel Per Inch |
96 |
Brightness |
250 cd/m² |
Contrast Ratio |
1000:1 |
Colour Support |
16.7 million colours |
Response Time |
8 ms (normal); 5 ms (fast) |
Vertical Refresh Rate |
50 - 76 Hz |
Horizontal Refresh Rate |
30 - 83 kHz |
Horizontal Viewing Angle |
178 |
Vertical Viewing Angle |
178 |
Screen Coating |
Anti-glare, 3H Hard Coating |
Backlight Technology |
LED backlight |
OSD Languages |
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese |
Features |
72% (CIE 1931) colour gamut, LED edgelight system, stand lock, Dell Custom Color, Flicker Free technology, BFR/PVC-free, Mercury free, Dell ComfortView, arsenic free |
Colour |
Black |
Dimensions (WxDxH) |
52 cm x 16.6 cm x 35.11 cm - with stand |
Weight |
4.78 kg |
Connectivity |
Interfaces |
DisplayPort , VGA , HDMI , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , 2 x USB 2.0 downstream (Type A) |
Mechanical |
Display Position Adjustments |
Height, pivot (rotation), swivel, tilt |
Tilt Angle |
-5/+21 |
Swivel Angle |
90 |
Rotation Angle |
180 |
Height Adjustment |
130 mm |
VESA Mounting Interface |
100 x 100 mm |
Miscellaneous |
Features |
Security lock slot (cable lock sold separately), LED indicator, VESA interface support |
Cables Included |
1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB cable |
Compliant Standards |
Plug and Play, DDC/CI, RoHS, EDID compatible, DisplayPort 1.2 |
Localisation |
India |
Security Slot Type |
Kensington security slot |
Power |
Voltage Required |
AC 120/230 V (50/60 Hz) |
Power Consumption Operational |
16 Watt |
Power Consumption Stand by |
0.3 Watt |
Power Consumption (Off Mode) |
0.3 Watt |
Software / System Requirements |
OS Required |
Microsoft Windows 7 / 8 / 8.1 / 10 |
Dimensions & Weight |
Dimensions & Weight Details |
Without stand - width: 52 cm - depth: 4.13 cm - height: 31.17 cm - weight: 3.11 kg , With stand - width: 52 cm - depth: 16.6 cm - height: 35.11 cm - weight: 4.78 kg |
Dimensions & Weight (Shipping) |
Shipping Weight |
7 kg |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Manufacturer Warranty |
Service & Support |
Limited warranty - parts and labour - 3 years |
Bundled Services |
3-Years Advanced Exchange Service and Premium Panel Guarantee |
Environmental Parameters |
Min Operating Temperature |
0 °C |
Max Operating Temperature |
40 °C |
Humidity Range Operating |
20 - 80% (non-condensing) |
Compatibility Information |
Designed For |
Dell Latitude 7400 2-in-1 , Dell XPS 15 9570 |
