Dell P2415Q 23.8" 3840x2160 6ms HDMI DP USB 4K LED Monitor
£341.04
25 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Exceptional screen clarity
  • Nearly perfect color accuracy
  • Full adjustability
  • All-digital connectivity
  • Eco-conscious design
  • Diagonal Size: 23.8in
  • Max Resolution: 3840 x 2160
  • Response Time: 6ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI, Mini DisplayPort, Mobile High-Definition Link (MHL)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £344.53
Save £1.50
Expect beautiful 4K clarity on Ultra HD monitor with high resolution, wide color coverage and reliable performance. Connect to laptops, tablets and other devices without compromising on picture quality. The high pixel density helps you see extremely fine details onscreen so you can view and edit higher resolution photos and more. Create your masterpiece with more clarity and color enhancement - all at a price you can afford. Each hue remains consistent from virtually any viewpoint with an ultra-wide viewing angle. Enjoy every detail with Dell Ultra HD 4K monitor which provides total comfort, thanks to full adjustability. Customize your viewing experience with a height-adjustable stand, or save desktop space by detaching the stand for wall mounting. With DisplayPort, you can daisy-chain two monitors side by side by connecting via the DP-in and DP-out ports, eliminating the need to link every one of your monitors to the PC and reducing cable clutter. Charge or power USB devices with a high-speed USB 3.0 charging port. Connect to MHL compatible smartphone or tablet and display content directly on the larger monitor screen via MHL. Made with premium-quality materials, this Ultra HD 4K monitor is BFR/PVC-free and has arsenic-free glass, a mercury-free LED panel, and a chassis made mostly of post-consumer recycled materials.
Product Description Dell P2415Q - LED monitor - 23.8"
Device Type LED-backlit LCD monitor - 23.8"
Energy Class Class C
Energy Consumption per Year 52 kWh
Power Consumption (On mode) 35 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz)
Pixel Pitch 0.13725 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 2000000:1 (dynamic)
Response Time 6 ms
Colour Support 1.07 billion colours
Input Connectors HDMI, DisplayPort, Mini DisplayPort, MHL
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Black
Dimensions (WxDxH) - with stand 56.664 cm x 20.5 cm x 36.953 cm
Weight 5.4 kg
Microsoft Certification Compatible with Windows 7
Compliant Standards Plug and Play, VESA EDID, DDC/CI
Designed For OptiPlex 3040
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Dell P2415Q 23.8" 3840...
£341.04
