See everything on the 24-inch WUXGA 16:10 monitor with versatile connectivity, a three-sided ultrathin bezel and ComfortView Plus.
Product Description | Dell P2423 - LED monitor - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class D | Power Consumption (On mode) | 14.8 W | Features | USB 3.2 Gen 1 hub | Panel Type | IPS | Aspect Ratio | 16:10 | Native Resolution | WUXGA 1920 x 1200 at 60 Hz | Pixel Pitch | 0.27 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 1000:1 (dynamic) | Response Time | 5 ms (fast), 8 ms (normal) | Colour Support | 16.7 million colours | Colour Gamut | 99% sRGB | Input Connectors | HDMI, DVI, DisplayPort, VGA | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 100-240 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 53.1 cm x 17.957 cm x 51.08 cm | Weight | 5.56 kg | Environmental Standards | TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified | Compliant Standards | RoHS, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free | Bundled Services | 3 years Advanced Exchange Basic Warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Built-in Devices | USB 3.2 Gen 1 hub |
Panel Type | IPS |
Pixel Per Inch | 94 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED edgelight backlight |
Features | Mercury free, arsenic-free glass, 3-sided bezeless, Dell ComfortView Plus |
Colour | Black |
Dimensions (WxDxH) | 53.1 cm x 17.957 cm x 51.08 cm - with stand |
Weight | 5.56 kg |
Connectivity | |
Interfaces | HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , DVI , VGA , USB 3.2 Gen 1 upstream , 4 x USB 3.2 Gen 1 downstream |
Mechanical | |
Tilt Angle | -5/+21 |
Swivel Angle | 90 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable - 1.8 m |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 14.8 kWh/1000h |
Power Consumption (Max) | 48 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption Sleep | 0.3 Watt |
Power Consumption (Off Mode) | 0.2 Watt |
On / Off Switch | Yes |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 53.1 cm - depth: 17.957 cm - height: 51.08 cm - weight: 5.56 kg , Without stand - weight: 3.52 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 7.71 kg |
Environmental Standards | |
TCO Certified | TCO Certified Edge Displays, TCO Certified Displays 9 |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
