Dell P2719H 27" 1920x1080 5ms VGA HDMI DisplayPort IPS L...
Dell P2719H 27" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
£217.18
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Diagonal Size: 27in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
This screen with 3-sided ultra-thin bezels is designed for seamless multi-display productivity with your all in one. Its small base frees valuable workspace.
Product Description Dell P2719H - LED monitor - Full HD (1080p) - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class A+
Energy Consumption per Year 27 kWh
Power Consumption (On mode) 18 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.311 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1
Response Time 8 ms (normal); 5 ms (fast)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Dimensions (WxDxH) - with stand 60.99 cm x 18.5 cm x 39.43 cm
Weight 6.28 kg
Environmental Standards TCO Certified ENERGY STAR Qualified
Compliant Standards Plug and Play, DDC/CI, RoHS, EDID compatible, DisplayPort 1.2
Bundled Services 3 years Advanced Exchange Service
Designed For Latitude 7400 2-in-1; XPS 13 9380, 15 9570
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Dell P2719H 27" 1920x1...
£217.18
