Stay productive, no matter where you work. Reduce harmful blue light with this sleek 27-inch FHD hub monitor with ComfortView Plus.
Product Description | Dell P2722HE - LED monitor - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class D | Power Consumption (On mode) | 17.1 W | Features | USB 3.2 Gen 1/USB-C hub, USB PD 65 Watt | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.3114 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal) | Colour Support | 16.7 million colours | Colour Gamut | 99% sRGB | Input Connectors | HDMI, DisplayPort, USB-C | Built-in Ethernet | Yes | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 100-240 V (50/60 Hz) | Dimensions (WxDxH) - with stand (lowest position) | 60.99 cm x 19.01 cm x 38.415 cm | Weight | 6.81 kg | Environmental Standards | TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Gold | Compliant Standards | RoHS, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free | Bundled Services | 3 years Advanced Exchange Service | Designed For | Latitude 5320, 5520; Precision 7560; Vostro 14 5410, 15 5510; XPS 13 9310 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Built-in Devices | USB 3.2 Gen 1/USB-C hub |
USB Power Delivery | 65 Watt |
Panel Type | IPS |
Pixel Per Inch | 82 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell ComfortView Plus, 99% sRGB colour gamut |
Dimensions (WxDxH) | 60.99 cm x 19.01 cm x 38.415 cm - with stand (lowest position) |
Weight | 6.81 kg |
Connectivity | |
Interfaces | DisplayPort 1.2 (HDCP 1.4) , DisplayPort output (MST) , HDMI (HDCP 1.4) , USB-C 3.1 Gen 1 upstream/DisplayPort 1.2 Alt Mode with Power Delivery (power up to 65W) , 4 x USB 3.2 Gen 1 downstream , Network (RJ-45) |
Mechanical | |
Tilt Angle | -5/+21 |
Swivel Angle | 90 |
Rotation Angle | 180 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support |
Cables Included | 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C cable - 1.8 m |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 17.1 kWh/1000h |
Power Consumption (Typical) | 16.99 Watt |
Power Consumption (Max) | 132 Watt |
Power Consumption Stand by | 0.2 Watt |
Power Consumption (Off Mode) | 0.2 Watt |
Software / System Requirements | |
Included Software | Dell Display Manager |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 60.99 cm - depth: 5.215 cm - height: 35.96 cm - weight: 4.92 kg , With stand (highest position) - width: 60.99 cm - depth: 53.415 cm - height: 19.01 cm - weight: 6.81 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 9.62 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8, TCO Certified Edge Displays |
EPEAT Compliant | EPEAT Gold |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
Compatibility Information | |
Designed For | Dell Latitude 5320, 5520 , Dell Precision 7560 , Dell Vostro 14 5410, 15 5510 , Dell XPS 13 9310 |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
