Experience pure productivity on a 27-inch 4K monitor with extensive connectivity and ComfortView Plus.
Product Description | Dell P2723QE - LED monitor - 4K - 27" - TAA Compliant - with 3-year Basic Advanced Exchange (PL - 3-year Advanced Exchange Service) | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class F | Power Consumption (On mode) | 26 W | Features | USB 3.2 Gen 1/USB-C hub, USB PD 90 Watt | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 at 60 Hz | Pixel Pitch | 0.1554 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 / 1000:1 (dynamic) | Response Time | 5 ms (fast), 8 ms (normal) | Colour Support | 1.07 billion colours | Colour Gamut | 99% sRGB | Input Connectors | HDMI, DisplayPort, USB-C | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 100-240 V (50/60 Hz) | Dimensions (WxDxH) - with stand | 61.16 cm x 18.5 cm x 53.52 cm | Weight | 7.21 kg | TAA Compliant | Yes | Environmental Standards | TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified | Compliant Standards | RoHS, NFPA 99, BFR-free, PVC-free | Bundled Services | 3 years Advanced Exchange Basic Warranty (PL - 3 years Advanced Exchange Service) |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Viewable Size | 26.96" |
Built-in Devices | USB 3.2 Gen 1/USB-C hub |
USB Power Delivery | 90 Watt |
Panel Type | IPS |
Pixel Per Inch | 163 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED edgelight backlight |
Features | Mercury free, arsenic-free glass, 3-sided bezeless, Dell ComfortView Plus |
Dimensions (WxDxH) | 61.16 cm x 18.5 cm x 53.52 cm - with stand |
Weight | 7.21 kg |
Connectivity | |
Interfaces | HDMI (HDCP 2.3) , DisplayPort 1.4 (HDCP 2.3) , USB-C 3.2 Gen 1 upstream (power up to 90W) , 4 x USB 3.2 Gen 1 downstream , LAN (RJ-45) |
Mechanical | |
Tilt Angle | -5/+21 |
Swivel Angle | 90 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support |
Cables Included | 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable - USB Type A to C - 1.8 m , 1 x USB-C to USB-C cable - 1 m |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 26 kWh/1000h |
Power Consumption (Typical) | 169 Watt |
Power Consumption Stand by | 0.2 Watt |
Power Consumption Sleep | 0.3 Watt |
Power Consumption (Off Mode) | 0.2 Watt |
On / Off Switch | Yes |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.16 cm - depth: 18.5 cm - height: 53.52 cm - weight: 7.21 kg , Without stand - weight: 5.05 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 9.68 kg |
Environmental Standards | |
TCO Certified | TCO Certified Edge Displays, TCO Certified Displays 9 |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
