Dell 24 Video Conferencing Monitor - S2422HZ 60.47 cm (23.8),3Y Base Adv Ex.
Product Description | Dell S2422HZ - LED monitor - Full HD (1080p) - 24" - with 3-year Basic Advanced Exchange (CA, US - 1-year Advanced Exchange Service) | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class D | Adaptive-Sync Technology | AMD FreeSync | Features | RGBIR camera, USB 3.2 Gen 1/USB-C hub, USB PD 65 Watt | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Pixel Pitch | 0.2745 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 4 ms (grey-to-grey extreme), 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal) | Colour Support | 16.7 million colours | Colour Gamut | 99% sRGB | Input Connectors | HDMI, DisplayPort, USB-C | Audio Input | 2 digital microphones | Built-in Webcam | 5 Megapixel - 1920 x 1080 at 30 fps | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare 3H hardness | Voltage | AC 100-240 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand (lowest position) | 53.78 cm x 17.47 cm x 37.84 cm | Weight | 5.6 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | RoHS, DisplayPort 1.2, BFR-free, PVC-free | Bundled Services | 3 years Advanced Exchange Basic Warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Viewable Size | 23.8" |
Built-in Devices | RGBIR camera, USB 3.2 Gen 1/USB-C hub |
USB Power Delivery | 65 Watt |
Panel Type | IPS |
Pixel Per Inch | 92.56 |
Vertical Refresh Rate | 48 - 75 Hz |
Horizontal Refresh Rate | 30 - 90 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, ultra-thin bezel design, Low Blue Light technology, 3-sided bezeless, Dell ComfortView Plus |
Colour | Black |
Dimensions (WxDxH) | 53.78 cm x 17.47 cm x 37.84 cm - with stand (lowest position) |
Weight | 5.6 kg |
Built-in Webcam | |
Sensor Resolution | 5 Megapixel |
Max Video Resolution | 1920 x 1080 at 30 fps |
Features | Windows Hello compatible, 75.4° field of view |
Audio Input | |
Type | 2 digital microphones |
Microphone Features | Noise-cancelling |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 5 Watt |
Connectivity | |
Interfaces | HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , USB-C 3.2 Gen 1 upstream/DisplayPort 1.2 Alt Mode (power up to 65W) , USB 3.2 Gen 1 downstream with Battery Charging 1.2 , USB 3.2 Gen 1 downstream , Audio line-out |
Mechanical | |
Tilt Angle | -5/+21 |
Swivel Angle | 60 |
Rotation Angle | 180 |
Height Adjustment | 110 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), integrated cable management, VESA interface support, fixed focus |
Cables Included | 1 x USB-C 3.2 Gen 1 cable - 1.8 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 13.5 kWh/1000h |
Power Consumption (Typical) | 13.5 Watt |
Power Consumption (Max) | 137 Watt |
Power Consumption Stand by | 0.2 Watt |
Power Consumption (Off Mode) | 0.2 Watt |
Software / System Requirements | |
Included Software | Dell Display Manager |
Dimensions & Weight | |
Dimensions & Weight Details | With stand (lowest position) - width: 53.78 cm - depth: 17.47 cm - height: 37.84 cm - weight: 5.6 kg , Without stand - width: 53.78 cm - depth: 5.674 cm - height: 32.357 cm - weight: 3.88 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 7.88 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
