Dell U2412M 24" 1920x1200 8ms VGA DVI-D DisplyPort LED I...
Dell U2412M 24" 1920x1200 8ms VGA DVI-D DisplyPort LED IPS Monitor
£162.49
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1200
  • Response Time: 8ms
  • Speakers: [N/A]
  • Interfaces: DisplayPort, DVI, VGA (HD-15)
Product codes
Enjoy widescreen performance, any way you want it. With a 24" 16:10 panel, IPS technology and LED backlight, the U2412M provides a brilliant view, plus amazing adjustability to suit any style.
Product Description Dell UltraSharp U2412M - LED monitor - 24"
Device Type LED-backlit LCD monitor - 24"
Features USB 2.0 hub
Panel Type IPS
Aspect Ratio 16:10
Native Resolution 1920 x 1200 at 60 Hz
Pixel Pitch 0.27 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 2000000:1 (dynamic)
Response Time 8 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Dimensions (WxDxH) - with stand 55.6 cm x 18.03 cm x 39.85 cm
Weight 5.73 kg
Microsoft Certification Compatible with Windows 7
Environmental Standards ENERGY STAR Qualified EPEAT Gold
Compliant Standards Plug and Play, DDC/CI, EDID compatible
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Dell U2412M 24" 1920x1...
£162.49
